- Oct 6, 2006
- 116,674
Ive been not using my Dev filter on hard surface jobs, yikes......
Ill need to rethink that slight benefit.
From a service perspective, we see a great deal more debris build up and sometimes damage to filters, strainers, and shut off valves on units owned by guys who do a lot of hard surface cleaning with their truck mounts.
We've had recovery tank shut off valve failure caused because hard surface materials accumulate on the floats like concrete, and weight them down to the extent that rising waste take water levels cannot lift them and engage the microswitch.
Good post.
I don’t use my TM for that. I use porty for hard surface cleaning. Don’t do much residential tile work, so need for TM. Don’t even use porty for slurry recovery.
VOLUME!I went into my local supplier just before Christmas to drop off holiday cookies. As I walked in the door, I was greeted by a sewage stench. No, not a backed up toilet smell, but the same, gag inducing smell of driving by a sewage treatment plant…
It was so bad, the company NEXT DOOR phoned the gas company, because they thought there was a gas leak…
Well, no, there was a old crusty CC with his TM in for service….
Dear lord, how do some of these guys stay in business?
Why, I do it the same as you except I use a crb with stiff brushes because I do it often. I use a turbo to rinse 1200 psi porty. For the most part I use Extreme in a hydraforce for the lovely scent.plz explain your ceramic tile process, including tools
Carpets get dirty and people clean them...That’s what waste tanks do. Get dirty
I use my back pack vac. No debris really... your getting sediment in your tank like you would for carpets?plz explain your ceramic tile process, including tools
Then Ashley had the right idea for this..instead of using using portable, he retrofitted portable to be connected to to TM. It came equipped with auto pump out so nothing went into tm tank.I don’t use my TM for that. I use porty for hard surface cleaning. Don’t do much residential tile work, so need for TM. Don’t even use porty for slurry recovery.
Filters are different in Georgia.I like how this idiotSees just using a basket filter the same as no filter at all
Never listen to Matt no madder WHAT!Never listen to Matt. Always use a filter.
I remember way back looking for change in my portable once when a lady insisted on her 50 cents change back from a cash job.Once when I forget my lunch money
Beauty design Ron.View attachment 112979
I like the Aerotech for the inline filters and the round bottom tank. It drains completely.
