Nate The Great
Well if you and @Jack Zipper Zerkie don't complain about the noise factor at your age, it must be quiet..
Noise = $$$$ Not bad for the small investment. Can't have it all. Great vacuum plenty heat . I have extra mufflers under the van to quiet it. jzWell if you and @Jack Zipper Zerkie don't complain about the noise factor at your age, it must be quiet..![]()
I did test is for noise before pulling the trigger. Supposedly Hydramaster won an award for thatWell if you and @Jack Zipper Zerkie don't complain about the noise factor at your age, it must be quiet..
ya honestly my 870s heat is amazing but it just seems overpowered so I only run on low and it provides more than enough heat and its very consistent. If I am dual zipper or spinner then I may bump it up but that is it.When I was looking into them back in 2017, they had problems controlling the heat.. Overheating issues..
Iām a simple man, knowing how to fix my own stuff, my location plays a big part in it as well.. I canāt just ādriveā my machine over to a dealer and have it taken care of..
What machine is the easiest to work on? I would think a Butler or SteamAction
Good choice. Max heat/max vac?I just bought another Butler today with a build date first week of September
Or⦠I could order my new system with oneGet chip to make your solution like electric
Nice. If I were buying a new machine I would look for a Cleanco or Butler PTO. I may in the near future if my move pans outYou betcha ā¦. Electric reel Mid mount unit in a 2020 Express 2500 with 4000 miles
I bought my first butler 6 months ago and it is nice it has more suction I think than my cds vans and I have the basic blower packageNice. If I were buying a new machine I would look for a Cleanco or Butler PTO. I may in the near future if my move pans out
You want to get rid of any live reels. That's where you can have air leaks. All you need is the vac connection to the waste tank. Don't use their filter box. If you feel you need a filter, use an inline one.I do! But it's not as easy to work out of.
And it has more connections that cause air leaks.
I've had more issues with the 2010 butler than the 02 WM. Van and machine.
You have some reason to think that is news to him?
That was off speed, right over the plateSee, youāre batting .500![]()
