Meter Maid
The Undetective
- Nov 29, 2017
- 3,867
- Name
- Chris
Another problem with electric vans and me is that when it’s freezing, and I do VLM, I let my van run for the heat, so my stuff doesn’t freeze.
I’m talking about commercial jobs. A few hours.you'll just have to hurry.......but there is a 2.5kw powerpack on the transit so you can run an electric heater for an hour or so....or plug it into the customers house
Soon. This one's ready for flight testing, already has orders from freight companies and airlines. Not sure how $85 million each competes with similar sized planes (that have far longer range), so maybe right now these are being purchased for the "look at me" factor.pretty sure there are no battery powered commercial airplanes
Eviation video
jalopnik.com
No, it's powered by the gas engine.Could the Hydramaster x drive work in an electric transit? I don’t understand how it all works
But it’s a gas engine powering an electric generator supplying power if I understand itNo, it's powered by the gas engine.
Yes. An electric transit wouldn't have enough power to power both the van and cleaning unit as well as heat. The x-drive uses a generator instead of a power take off shaft but still uses heat exchangers from the vans cooling system.But it’s a gas engine powering an electric generator supplying power if I understand it
So if the van could just power a blower then we run a small fuel fired heater it would be good?Yes. An electric transit wouldn't have enough power to power both the van and cleaning unit as well as heat. The x-drive uses a generator instead of a power take off shaft but still uses heat exchangers from the vans cooling system.
Sure but you need one heck of a battery to get any range out of it. Fuel fired heaters are an option but can be messy, unreliable or downright dangerous in the wrong hands. Not a great option if you have multiple techs.So if the van could just power a blower then we run a small fuel fired heater it would be good?
Crap we are doomed lolSure but you need one heck of a battery to get any range out of it. Fuel fired heaters are an option but can be messy, unreliable or downright dangerous in the wrong hands. Not a great option if you have multiple techs.
Hydrogen may have some answers. Already they are replacing electric forklift batteries with drop in fuel cells. The technology should be adaptable for a truck mount. Hydrogen fuel cell can power an electric heater or burn just like propane in a heater.Crap we are doomed lol
China behind the Green New Deal? That is a conspiracy theory!Like I told you before it comes down to raw materials. China owns the electrical tech industry because they own the raw materials needed.
I think they are the pushers of the green new deal.
I think the plug should be in the rear since thats is how its gonna feel when you have to pay 90,000 or more for a new electric van.
Problem is they dont wanna actually burn the hydrogen, they want to use platinum to strip the electrons to make electric. So requires precious metals. Plus the emergency response team will just be a paveing team to fill the hole where your car blew a hole in the road.Hydrogen may have some answers. Already they are replacing electric forklift batteries with drop in fuel cells. The technology should be adaptable for a truck mount. Hydrogen fuel cell can power an electric heater or burn just like propane in a heater.
I could answer each one of your questions, but I don't have the time. I'm going for a ride.There's nothing efficient about the current selection of electric cars. Technology today should allow these cars to charge themselves. Hell, look at our current automobiles. We have an alternator that recharges the batteries. Why can't today's electric cars recharge when the wheels start turning. And solar panels? Why aren't they on the roofs? Combine the alternator with solar roofs and it should hold it's own charge. Total scam
I agree that burning hydrogen is probably not the way to go but it's no more explosive than propane or natural gas. We don't see a lot of explosions from those vehicles.Problem is they dont wanna actually burn the hydrogen, they want to use platinum to strip the electrons to make electric. So requires precious metals. Plus the emergency response team will just be a paveing team to fill the hole where your car blew a hole in the road.
It doesn't have to be the wheels only. They could put a belt onto the electric engine the same as gas engines to move the alternator. Alternators come in many different sizes to charge the batteries. The concept of that is to help keep the battery fully charged, not to recharge it from being a dead battery. So it's highly possible for this to be normal. Depending on plugging up the car only at a charging station or your house on a secondary charging cable is bassackwards on the technology improving.....but they are relatively efficient
couple things here
your car is converting the energy from gasoline to electricity to charge a relatively small battery.....with about 25-35% loss
todays cars do have regenerative braking but "while the wheels are turning" is just parasitic/inefficient power (no net gain)
solar, which some have, would increase range but you would need much more surface area/collector efficiency to recharge at the rate needed for a car to charge itself under normal use (currently)
without solar (external input) you're talking about a perpetual motion machine....second law of thermodynamics and whatnot
Could use a wind up key too.Alternators consume more power than they generate....you would be using the battery to power a device that then feeds less power back to the battery
and again there is regenerative braking....
