TOPS Spot
Swani
If you know, you know. If you don't, it sucks to be you. 20230226_175558.jpg
Reactions: Mike J
Claim?
No, I don't even want to know what 4 VacAway products make up this concoction, but I and 1000's of other highly approve.
Reactions: Living The Dream
It doesn’t matter if it foams. Just rinse over it and let the white spot dry. It’s an encapsulate … doofus.
Reactions: Walrus Gumboot
People assume the white halo will stay and I've seen the concern when using it with hot water extraction, but it's some weird reaction with the surfactant and it always goes away within a couple minutes if not less even with wool, but that's usually a sign that they're using it to concentrated
Is it better than Cyclone?
Dont recall ever trying Cyclone, not even sure who makes it, but top spot gets rid of everything that sells does and CTI yellow gel and wd-40 and butyl base spotters and virtually everything other than 40 volume peroxide and rubbing alcohol on occasion.
Don't be so negative. Chances are your favorite products are rebranded. I hope things are going good for you guys. Take care!
He only pretends to hate it because he ignorantly thinks I profit off of it, which I don't, unless I'm selling it direct, which I do.
Lamesalegend
Tops Spot is a great spotter. But I miss GumUp. GumUp was replaced by Tops Spot in the Trinity Line. GumUp seemed to work even better on sticky things like Gum, slime. Last time I tried to order GumUp I was told they discontinued it because Tops Spot worked the same. I think its a little different it actually foams less then GumUp did. I feel like Tops Spot is probably a combination of Cyclone and GumUp, I may be wrong, just guessing
for things like chewing gum, aren't you supposed to use it undiluted?
I invite all of you to pour an ounce UNDILUTED on the heaviest traffic'd area in your own home and watch what (doesn't)happen over time.
Just let it dry, no blotting or anything.
So, is it safe to say we’re all Tops Spot fans? My one kid who actually cleans some carpet when she can’t get me or someone else to, loves it.
Evets
We had to use defoamer whenever we applied it. My son formulates our chemicals. Einstein? Yeah.
