- Oct 6, 2006
- 117,202
Wand jetting for third worlders
spray bars and flood jets have already been proven to suck, over allThere are other options for jets...But your designing the newest best so go with what ya know -regards and good luck...
8 or 6(not sure on the flow)
six 01 jets=6 Flow, four 1.5 jets equals 6 Flow and two #3 jets equals 6 Flow...
less jets, same flow, more impact with fewer jets
#3 jets will give you more water with less impact.six 01 jets=6 Flow, four 1.5 jets equals 6 Flow and two #3 jets equals 6 Flow...
yeah Matt I added coffee to lie to my audience so that I could sell more jets, which I dont.. you use more coffee I see
Idiot. I’m not saying you’re lying.yeah Matt I added coffee to lie to my audience so that I could sell more jets, which I dont.
Maybe I should start selling garden hoses.
I meant you use more coffee by pouring in the last two cup from the original 6 cups
I DID NOT add more coffee to my display, MattIdiot. I’m not saying you’re lying.
Your arrogance needs to calm down and take some positive criticism
I’ve owned several different wands in the last 20 years , cheap and high dollar so I know what I’m talking about
side by side observation demonstrated that a stock 6 jet Ti (06) flow needed to be a minimum of 450-500psi to equal cleaning results of an AW29 at 300-350psi (06 flow)
I never said you didI DID NOT add more coffee to my display, Matt
This was from the Cc before me
I prefer the ( modified) AW's head weight and S bend but those wands are excellent cleaners.Mike I run two 02 jets on my Evolution and Sharpshooter wands at 450psi. I find they keep the heat up as well as do a sensational job cleaning and flushing carpets. I clean Restaurants, Common Halls, Apartment complexes and all types of residential carpet. No concern of fiber distortion. Uniform deep cleaning . No clogged jets. Never have an issue with cleaning either. Mind you, I believe in agitation and quality pre conditioners to prepare for extraction too. I have great experience with the butler 14 and 18" wands. They did a great job, but I feel the 2 jet with 02 cleans just as well with way less water consumption. Which to me is a very important part of cleaning. The AW29 is a great workhorse too. Just a bit heavy compared to its plastic counterparts.
