- Aug 9, 2012
- 11,536
- Name
- sam miller
How's your buttocks?sounds scientificy enough..
I'll try it today
I'll try it today
the secondary filter is a FILTER, so you would loose that filtering efficiency IE more stuff in the waste tank. So if you purchased the Devastator for filtering, then you loose some of that capability.Plz explain your theory.
super stoutI think I'm going to buy the Steam Action inline filter. It looks pretty awesome.
What is this and where does it go? And where do you get this? Thanks !!Talk about airflow! I had the silver bullet Devestator, but the puddling at the bottom of it was very annoying, and sloppy to change out bags. This gives me maximum performance and is easy to swap out bags.
Mikey is no longer in love with the Devastator filter so he’ll tell you something else is better (this week) but you can find them at devastatorfilter.com.What is this and where does it go? And where do you get this? Thanks !!
each day I replace the paint strainer. I also rinse out the secondary filter. I find that the secondary filter still catches a lot of debris which would otherwise go into the waste tank.the secondary filter is a FILTER, so you would loose that filtering efficiency IE more stuff in the waste tank. So if you purchased the Devastator for filtering, then you loose some of that capability.
And its not a theory, its a fact.
It fits into the waste tank directly under the intake ports. My AquaTech nits came with a metal basket which would catch the debris entering the tank. I cut off the bottom of the baskets, leaving just the top lip to hold the paint strainers.What is this and where does it go? And where do you get this? Thanks !!
