- Oct 6, 2006
- 117,396
Not so much your dry strokes...
I use a 2 jet wand most of the time.. i try and move the wand so second pass the jets hit where they didn't the first past.
I often see the 2 lines made by the jets so I try to neutralize that.
But that's just the norm. I have a technique I move right then come back left then right then back to the left. Lot of over lapping. It leaves a more even look.
That's jus mean.......!Isn’t “misaligned “ and Steve synonymous?
Truth.That's jus mean.......!
Even a single jet i see the distortion. Low pressure doesn't help. It's the cheap ass carpet most people buy.If you're seeing lines with a two jet wand something is misaligned or your jets are worn out
I can just tell so I go over it and over it. It gets them cleaner anyway so no biiggee.
I really don't want another disposable item.
I know the carpet is already a type of plastic but where is all that nylon going?
I read somewhere that today’s nylon toothbrushes are killing our teeth. But I think that info was an advertisement from a natural toothbrush companyInto your colon and nervous system, no doubt...
Look at the upside. You only have one cavity.Since I only have one TOOF , I use a TOOF brush
