I just got a rx20
Someone local gave it to me for a trade on a burnisher I had sitting around
Any tips on how to get the best out of these machines or should I just put it up for sale somewhere.
You know I’m a wand guy, but if it can make my job any easier on trashed carpet, I’m open for suggestions.
Reactions: Dwain Ray
You'll complain about it anyway.. Give it a go.. ChemDry loves them at 200psi..
It's a love it or hate it for older geezers.. Too heavy for them to take off the truck, while people who love rotary extraction swear by them..
Which model do you have? The old low speed has a horizontal motor while the newer ones have the vertical motors.. Some have glides but not sure if GG still offers them.. You can get a bonnet head to use it for scrubbing or padding..
Show a pic Woody!
I’ve never used one, so I can’t give you any advice specifically related to it. However, if it’s anything like a Rotovac, then I’d like to suggest that you keep it around until you run into a job that is so trashed that you really don’t want to clean it. You might be happy you have it.
Don’t get in a hurry.
Might want to turn your pressure down.
If drying time is a concern, bring fans.
It's going to hurt your back as you're too tall for it but if you like the results put some Glides on it which will raise it more than an inch
The handle is probably too short for you. Good machines but slow and they use a lot of water. Good on trashed commercial carpet as the cleaning heads are individually spring loaded unlike the rotovacs.
Where the RX20 does shine is the uneven floors.. It'll contour to them..
Long ago, Orbitec Clark made a retro kit for the RX20 that I would have loved to have.. His son Scott would probably be down to make it again.. It kept the wheels down on the ground while pushing it, removing the need to balance it..
So from the feedback from you guys, it seems to be slower, can overwet the carpet if not having the pressure of the water balanced out right, and is too short, and only needs to be pulled out cleaning Chinese restaurants.
I'm glad I didn't pay any money for this anchor
but I'm still curious what it can do, so when the time arrives soon, I'll bring it to a job at a trashed rental on one of my slow days and I'll try to make a fun video for Marty to watch. It'll be better than my Walmart video, lol
Dr. Kleen
Jodi Fandozzi
I used one for about 20 years… loved the results on trashed carpet. It is a little slow at times but it is consistent throughout. If you’re tired and on job 3 or 4 for the day it will do the same work as it did when you first started. As long as you figure out the pressure you need (sweet spot) to thoroughly rinse without over wetting. Customers used to like to watch it also. I haven’t used mine in years but dont want to let it go. Never know, lol
The sweet spot pressure. Someone above mentioned 200psi. what was your sweet spot?
And does anyone know the flow of these jets on it?
jack zerkie
Not so bad will clean dirty carpets also used for flood work on carpets nothing is 100 % give it a try.
The options are endless.. Cone spray jets for the portables.. Capping 2 jets to reduce flow.. Half-closed jet slots to help smaller machine recover more..
I'm old enough to remember CD using rx20 and wands in their smear campaign ads.. Funny how things come full circle.. 175 and thick pads were their thing unless Carpet Mills didn't recognize their method and void warranties.. Suddenly, they're Hot Water Extracting the very thing they were bashing.. Sorry, I have no love for a franchise that tried to black eye the industry.. Hell, even the glide wars.....
Pull a trailer when you use it on commercial and it won’t be an anchor. I bought one for $150 recently because of the newer handle release. Since you don’t like encap, it’s the cats ass on commercial if you’re not in a hurry. I’m short, 5’8, so it fits me fine. The handle will adjust like a 175. You can Run over the carpet with a zipper and make it dry faster. I would not use it on residential except as you say an empty rental.
As long as it doesn't hurt your back bending over, it will deliver amazing results. A lot of guys who have used them have a love/hate relationship with them.
Andy
Doesn't Matter
Learn to use going forward and back will help speed it up some. Because you will be controlling the rate of speed. Where as side to side the speed of the machine dictates it. Play with the PSI to find the sweet spot. The spin is moving the head away from the water not into it. It is creating more of a glancing blow than a direct hit. The wheel attachment Nate mentioned would be nice, would be like running a phoenix with hoses.
If you can run a 175 proficiently, the front back motion in pretty easy. The RX is a little more difficult operating than a 175 with a pad on water.
Dwain Ray
back in the 80's when rx20's first came out i wasn't convinced i needed a 2500.00 attachment to make my 15,0000(that was an expensive tm then)carpet cleaner work better . Like you sometime around the mid 90's i ended up with one. Got it for free. It had froze and didnt work. It sat around my shop in the way for 6 or 7 months. 1 day i got a bug up my ass and got it to work. The next day i went out and bought a brand new one and from that day on I've used a rotary on every job. I love um! However I do clean carpets a little differently . After prespray i clean and dry with rotary and use an emulsifier. Then switch to a rinsing agent and clean and dry again with a 45 year old drag wand. Below is my shop carpet after replacing the entire front end on a chevy 3500 van and a ford ranger, yep thats alot of bearing grease!
20201019_151359.jpg 20201019_155520.jpg 20201019_162938.jpg 20201019_172111.jpg 20201019_172908.jpg
Reactions: Kenny Hayes
Dwain Ray
A Zipper would be a lot better for that last step if you insist 😬
Probably, but I've been using steamgeni drag wands since i got the first one with a 731 portable in 1978 and the one i use now came with a new steamgeni 733 portable i bought new in 1979 since then I've aquired 5 additional including a nos one my supplier gave me for my birthday (it's on my Frankenstein machine) also i have a 12" steamgeni drag wand i use for tiny homes/ 5th wheels and area rugs so in short im already committed
jessi
Jessi Lopez
Have you used it? I loved the rx20 when i used it at my old job. I just have a 175 now
