- Oct 22, 2012
- 28,145
- Name
- Ron Marriott
Half the strength of the ones he's on now.What kind of prescriptions were you on 8 years ago?
Chill and get paid.....next time set up the job and then stiff em....!Just be patient Matt get paid then never go back!
Can't remember....Half the strength of the ones he's on now.
How can a carpet wick if the top of the fibers are dry? I've been under the impression that if you can completely dry the upper portion of carpet fibers using adequate dry passes, air movers, etc... than the moisture remaining below that level will evaporate off as humidity and the emulsified soil will stay at that level as it slowly dries completely. Basically how can emulsified soil wick to the top of a fiber if that portion is already dry?Looking at it today may not be helpful... I think it will reveal itself in about 6-7 days.
I would assume today it will still be wet. (even if it's dry to the touch on the top)
If it is a rubber backing type....I guarantee you it's still wet.
Kerosene and a matchI'll be doing it next week. The carpet is 10years old and has never been cleaned.
What would your process be?
Thanks for bringing this back to memory. The number 1 lesson I learned on this job was:I was thinking of this thread off and on as I was cleaning with the Cimex today. Great stuff, super helpful. Thanks for the bump Woody!
-This carpet has a rubber backing. Blast that dirt out. Turn the pressure up and pressure wash it. You won't damage it or cause any "browning"
having spin marks from a zipper is a no no. Or the zipper bouncing more than a rabbit while trying to pull is another frustration. The cx15...that's a joke.Minus well use a turbo spinner with a teflon ring.. Or a zipper SS, or a CX15, or save the headache and not do it..![]()
The non vacuumer Slot fans suffer in many ways for their laziness..Yeah, right after I allowed myself to not let my preconceived notions about a certain poster cloud my thoughts regarding this subject, it popped into my mind that I’ve always ran two hole glides on my zipper.
(Not afraid to charge more for vacuuming.)
How about vacuuming, scrubbing with a Cimex, extracting with a TM at 800+ psi, and 10k cfm of air for about 30 minutes?
800?
You can put wash installed carpet.
Do yourself and your customers a huge favor and get rid of your hero complex as soon as possible
And almost all instances less is more.
I appreciate helpful input Mike. However spare me your assumptions and preaching about a hero complex. I am simply asking questions, learning, and sharing ideas. It literally seems like your the one with a hero complex. I clean all residential carpet with 400 to 450 psi, and commercial at 500 psi.
This thread is about ridiculously soiled carpet at a neglected Walmart entry way. Matt mentioned possibly using 900-1000 psi in the most difficult to clean environments, I responded with a question shaped in the form of a proposition.
I do a pretty good job. But he has me on his ignore list lol.It’s not possible to shame a narcissist
When I first started 40 odd years ago we used 100psi machines hot tap water and a swing buffer with a bassine brush on the heavily grotted up polys. They cleaned up well.How about vacuuming, scrubbing with a Cimex, extracting with a TM at 800+ psi, and 10k cfm of air for about 30 minutes?
Geeze, we're talking mats here. How much time can you spend on a mat before you tell them to throw it away, if it don't look good.
How many things does he do that make sense?!?
This business can get lonely and boring sometimes. Making sense doesn't require a conversation starterWoody started the thread.............How many things does he do that make sense?!?
