Has anyone ever cleaned the entrances at a Walmart?
Bryce C
DFW
Bryce
Regarding wicking
Looking at it today may not be helpful... I think it will reveal itself in about 6-7 days.
I would assume today it will still be wet. (even if it's dry to the touch on the top)
If it is a rubber backing type....I guarantee you it's still wet.
How can a carpet wick if the top of the fibers are dry? I've been under the impression that if you can completely dry the upper portion of carpet fibers using adequate dry passes, air movers, etc... than the moisture remaining below that level will evaporate off as humidity and the emulsified soil will stay at that level as it slowly dries completely. Basically how can emulsified soil wick to the top of a fiber if that portion is already dry?
Wet seeks dry.. Evaporation.. Which is why it's called wicking.. If the bottom is impacted with soil, you'll always be fighting an uphill battle.. This is why VLM works well so as not to disrupt the deeper soil.. VLM is an interim cleaning method made for commercial carpets.. It is appearance cleaning..
Bryce C
DFW
Bryce
I was thinking of this thread off and on as I was cleaning with the Cimex today. Great stuff, super helpful. Thanks for the bump Woody!
  • Love
Thanks for bringing this back to memory. The number 1 lesson I learned on this job was:
-This carpet has a rubber backing. Blast that dirt out. Turn the pressure up and pressure wash it. You won't damage it or cause any "browning"
Reactions: Bryce C
Minus well use a turbo spinner with a teflon ring.. Or a zipper SS, or a CX15, or save the headache and not do it.. :lol:
having spin marks from a zipper is a no no. Or the zipper bouncing more than a rabbit while trying to pull is another frustration. The cx15...that's a joke.
I"m more speculating on cranking that psi up to 900-1000 on the wand. The dirt was so hard packed with asphalt soiling form the parking lot, that the average 500-600psi is a joke on thinking you're pulling anything out
Reactions: Bryce C
I don’t have a spinner Zipper, but my standard Zipper has NEVER “bounced more than a rabbit while trying to pull”.
I’m thinking you made that up.
Incorrect glide set up or improper wheel height setup will cause hopping.
Yeah, right after I allowed myself to not let my preconceived notions about a certain poster cloud my thoughts regarding this subject, it popped into my mind that I’ve always ran two hole glides on my zipper.
(Not afraid to charge more for vacuuming.)
The non vacuumer Slot fans suffer in many ways for their laziness..
Bryce C
DFW
Bryce
How about vacuuming, scrubbing with a Cimex, extracting with a TM at 800+ psi, and 10k cfm of air for about 30 minutes?
800?
You can put wash installed carpet.
Do yourself and your customers a huge favor and get rid of your hero complex as soon as possible
And almost all instances less is more.
Bryce C
DFW
Bryce
800?
I appreciate helpful input Mike. However spare me your assumptions and preaching about a hero complex. I am simply asking questions, learning, and sharing ideas. It literally seems like your the one with a hero complex. I clean all residential carpet with 400 to 450 psi, and commercial at 500 psi.
This thread is about ridiculously soiled carpet at a neglected Walmart entry way. Matt mentioned possibly using 900-1000 psi in the most difficult to clean environments, I responded with a question shaped in the form of a proposition.
Bryce C
DFW
Bryce
Hey look what the sage Jim P. posted regarding his critique of what's wrong with forums like this:
"5. Cleaner networking sites are not always well policed, and those asking questions or even being supportive an answering questions can be subject to abuse and ridicule."
I'm simply asking a question trying to learn in good spirits, and the owner of the forum is...
We ALL go through the Hero stage.
Most never leave and over clean everything.
I'm trying to "spare you" in a way you won't understand for quite some time
Less is more on soil impacted carpeting.
roro
Ross Craig
When I first started 40 odd years ago we used 100psi machines hot tap water and a swing buffer with a bassine brush on the heavily grotted up polys. They cleaned up well.
If faced with similar today we would use Cimex with stiff brushes (not pads), and hot water about 100C or more and probably at about 200 psi with slooooow strokes.View attachment 1756085153610.webp
Geeze, we're talking mats here. How much time can you spend on a mat before you tell them to throw it away, if it don't look good.
Honestly I worked on one in the admin entrance at one of my churches. Had one spot that would wick back. After the second go, the business manager said toss it, I don't like it anyway. Then asked me to find them new mats😂
Latest Auctions
