- Apr 17, 2009
- 10,230
- Name
- Kenny Hayes
I saved your post. I need that for me personally in my house.
WHY DOES MY PHONE SAY I'M IGNORING CERTAIN MEMBERS?I get it, and there's nothing wrong with a 175, but we're talking to a long time P R O here. Don't #blush Sam!
That's good stuff, but I wish they would put it in a bottle and also get better labels.CTI Power Gel works great on filtration lines. https://excellent-supply.com/produc...-15-oz-118-ml-tube-commercial-carpet-cleaning
It's a smart phoneWHY DOES MY PHONE SAY I'M IGNORING CERTAIN MEMBERS?
Interesting discussion going on here. I'll start by saying that HWE is still the most efficient way to flush the highest level of contaminants from the carpet in a single shot. And that can be helpful in the case of a pigged out neglected carpet. However, to think that HWE alone can remove everything from the carpet is not realistic.
When we apply pre-spray we're adding a strong detergent, because we need the firepower to break up and emulsify soil. Now we have 2 components to rinse (1) pre-spray and (2) carpet grunge. We'll call that combination the "HWE target load".
So can HWE work to eliminate all of the "HWE target load"? No, it simply can't.
To illustrate: Consider taking 1 gallon of red paint / representing the "HWE target load". Now let's dilute the gallon of bright red paint 5 to 1 with 5 gallons of hot water. What do you have? It's still bright red! Dilute it with 10 more gallons of water. Still bright red. Add 25 more gallons of water. What do you have? Still red. It would take hundreds of gallons of water to get the water to a level that you can't see a trace of red.
That illustration describes the HWE process. The "HWE target load" is reduced (somewhat). But through the process of dilution and extraction, there will always be some remnant of the "HWE target load" left in the carpet. Anyone can easily recognize this fact. Even when an extremely effective HWE cleaning is performed, there would still be some "HWE target load" (i.e. red paint) left behind.
With encapsulation the soil can continue to be recovered after the initial cleaning / providing that you have an encap product that dries to a brittle crystal polymer that can be extracted through routine post vacuuming.
To be 100% honest, no cleaning method is completely perfect. So to say that any method achieves 100% soil removal is ridiculous. Our place as cleaning professionals is to reduce the "HWE target load" to the highest level that's reasonably acceptable. To imply that a method delivers total sanitizing, when we're dealing with carpet fiber, is simply not realistic.
This video about encapsulation pre-spray explains how adding an encapsulation component to our pre-spray can further reduce the "HWE target load".
I wouldn't put it in my portable♂
I'd mist it on.
BingoI’m not anti VLM. VLM/encapsulation absolutely has its place. We use it in quarterly rotation with HWE on commercial and we will often use it in conjunction with HWE in residential. Typically post bonnet.
But for residential carpet, hot water extraction should be the primary system. VLM just doesn’t check all the boxes.
I’ve had quite a few homeowners ask me about VLM after someone tried to sell them on it as “the new, better way.” I always ask them one simple question. How do you think they clean their bonnets?
They’re not spritzing them with a little encap, wiping them with a rag, and giving them a quick vacuum at the end of the week. Those pads have to be properly washed between jobs.
Once I explain that, most people instantly get why I lead with HWE for residential and only use VLM/encap as a tool, not a replacement.
WHY DOES MY PHONE SAY I'M IGNORING CERTAIN MEMBERSI get it, and there's nothing wrong with a 175, but we're talking to a long time P R O here. Don't #blush Sam!
I'm not suggesting not using Punch, I just wouldn't run it through my porty. That's just me. It
says you can, but it is an encap. I use it when using a polisher on chairs.
Why does my phone say I'M ignoring certain memories!!!¡!!I'm not suggesting not using Punch, I just wouldn't run it through my porty. That's just me. It
This week I did some furniture cleaning at 2 Houses. I did one on Monday and after the sister saw the job she called me to do hers
Both Sisters have 2 German Shepherds that lay on the furniture. Lucky for me both Sectionals were dark blue but still were atrocious
I used Punch as a Rinse Detergent at 1 oz per gallon in my Heated Portable ( water gets to 200 degrees ) and was very pleased with the results and so were the customers
After doing those jobs I thought maybe I should have used it at 2 oz. It says on label 1-2 oz per gallon for portables but I think that is for carpet not furniture
What are your thoughts on using Punch as a Rinse Detergent on TRASHED Furniture
You're HIGH again so you're imagining strange messagesWhy does my phone say I'M ignoring certain memories!!!¡!!
But he can't remember who he's ignoring! Oops, there I go!Probably because you're ignoring certain members, ya ol' coot!!
If he had that low of flow, he might of actually dried a carpet like the rest of us.That just tells me (when you had a machine that looked like a good truckmount) that you didn’t HWE carpet properly
I bet you
-did your wet passes in the triangle pattern
-had a 2 jet wand that was 2-3 flow
-rinsed at maybe 350psi
-didn’t do slow dry passes.
-never changed your blower belts because it was “too hard” to get access
-had your lift set around 11-12
Which made your mind calculate that HWE was terrible method. I understand. That’s why there’s mental facilities for those who were just taught the wrong way. It’s called a class and they teach you the proper way to HWE carpet.
Excellent Work !!!If he had that low of flow, he might of actually dried a carpet like the rest of us.
Soaker hahahaha
I'm a fan of my fans
View attachment 133136 View attachment 133137
Your agitating alrightI will NEVER go back to those days when I needed fans to dry carpet FAST
Now I get Residential Carpet CLEAN and DRY in 1-2 Hours without fans
It's not the 1990's anymore
My 4 Dri Pod - 2 Air Path - 2 Turbo Dryer just collect dust today
LESS water MORE agitation !!!
I like Procyon plus powder as a rinse. On fine fabrics I sour it with Ultrachem Labs Neutralizer.Most of the time I just rinse with water but this furniture was nasty. It needed more than just water
Why not in portable ?
And what would you recommend I use on TRASHED Furniture with portable ?
DOAHWHY DOES MY PHONE SAY I'M IGNORING CERTAIN MEMBERS?
It's you!DOAH
Why does my phone say I'm ignoring certain members?I saved your post. I need that for me personally in my house.
I use Procyon Plus to clean my bonnets and have used it as a rinse but don't carry it on my vanI like Procyon plus powder as a rinse. On fine fabrics I sour it with Ultrachem Labs Neutralizer.
I know all you guys here do excellent work but there are a lot of guys out there using TM's that are SOAKERSYour agitating alright![]()
You finally hit the nail.I know all you guys here do excellent work but there are a lot of guys out there using TM's that are SOAKERS
SOAK and Leave
But all you guys using the HWE Method get a bad name because of the SOAKERS
I do move outs at one Apt Complex and the maintenance guys tell me about tenants having carpet Steam Cleaned by SOAKERS and carpet still being wet the next day Stanley Steemer
They have had me go in and reclean jobs after SOAKERS because of wicking
I did one last week because it looked like it wasn't cleaned but it was and that one wasn't Stanley Steemer
Every time tenant moves out carpet must be cleaned before new tenant moves in
Tenant moving out must pay for and get carpet professionally cleaned with proof (receipt) to get their security deposit back
If tenant doesn't get it cleaned Apt Complex has me clean it and money gets taken out of tenant security deposit
Apt Complex recommends me but some tenants find cheaper Company
I only use Procyon Plus as a detergent in my portableOne word of caution regarding Procyon and CRB machines: Be careful if you're using it with you CRB. Our mechanic/tech guy at Excellent Supply has seen significant damage repairing CRB's – when cleaners have used Procyon. It's corrosive!
SOAK and Leave Company's like Stanley Steemer are NOT cheapYou finally hit the nail.
Those who want cheap get cheap work.
