Cleaning all carpet in a hotel
Amritgcalgary
Amrit
Role
Cleaning Professional
Years of Experience
2
I recently landed a hotel carpet cleaning gig and they are wanting to clean the carpets in the ballrooms, hallways lobby etc. every 3 months(about 40,000 square feet)
for the ballroom(16000 sq ft open area), I have been using a 20 gal karcher walk behind self propelled extractor(BRC 46/76). It did a decent job but i didn’t see a huge difference. I spot cleaned some of the stains afterwards with my portable and wand.
I pre sprayed the areas working one section at a time and then ran my karcher unit with just hot water in the fresh water tank. Should I be adding some sort of solution to the fresh water as well?
I was hoping I would see more of a pop on the carpets after extraction but I didn’t get that.
Maybe the carpets were still damp?
Do you clean the filter often, or touch the carpet with your hand to check performance?
Adding a rinse agent could help.
Do you have any advice on how to land these cheap hotel owners?
Or did you claw your way above the hotel to the corporate office?
I can’t give any suggestion on the karcher. I’ve never cleaned with one.
Which specific model did you use?
My advice is buy a Cimex and use Releasit products and go to town. Use fiber or fiber plus pads for the win. Every 3 months it will pay for itself.
sassyotto
Paul
although not a fan, if its every 3 months you could use VLM with Cimex or other whats ever popular now machine.
After thinking about it, if it were me, I would prespray an area, use a wide 20 inch Brush Pro to agitate and then your walk behind. Why? Because VLM, done the right way, doesnt save time.
Axel70
Russ Wooten
Role
Years of Experience
20
This is the answer! You will be amazed at the results. I use my Cimex at a senior living facility and they had always used Chem Dry or Stanley and they were blown away by my results.
kingzm
king
Role
Years of Experience
1
Thanks everyone for the input — really appreciate all the insights.
Based on your experiences, it sounds like running plain hot water through the Karcher may be a big reason I didn’t see the “pop” I was hoping for. I’ll definitely look into adding a proper rinse agent or switching to an encap/VLM approach for maintenance cleans, especially given the 3-month cycle and large square footage.
The Cimex + Releasit combo you’ve mentioned seems to have strong support here, so I’ll be researching that setup further, particularly for heavily trafficked areas like the ballroom and hallways. In the meantime, I’ll experiment with better pre-spray agitation and a suitable rinse to improve extraction results.
If anyone has recommendations on specific pre-sprays or rinse agents that work well with the Karcher BRC 46/76, I’d be grateful to hear them.
kingzm
king
Role
Years of Experience
1
Axel70
Russ Wooten
Role
Years of Experience
20
Axel70
Russ Wooten
Role
Years of Experience
20
I have to say I use a Cimex with Releaseit DS2 and any tough traffic lanes I use Encap-Punch. For spots and stains, Stain 1 is great. I had a huge spill in a hall, someone spilled a full mop bucket full of very nasty water and left a 6 foot round dark stain. I used Encap-Punch as a prespray, agitated the stain with a Powr-Flite Multiwash and went over it with my Cimex as I did the hall and the stain was completely gone. I went back 2 days later and it was still gone. I've done commercial carpet everyway you can think of and telling you VLM is the way to get amazing results and save money and time. By the way the Releaseit products really are the best IMO, they will amaze you and your clients. Good luck
Reactions: Kenny Hayes
A walk behind machine like that fails to give decent results because it tries to do everything at once.
Great results rely on a well-balanced application of chemistry, temperature, agitation and dwell time
You've taken chemistry and dwell time out of the equation and unless that water is being heated somehow, you're now down to just agitation..
If it were me I would pre-spray a few hundred feet at a time, run just the agitator portion of that machine over it whether it's cylindrical or a circular ,and then go back over it with a acid rinse that has some clean ability to it, and extract.
Axel70
Russ Wooten
Role
Years of Experience
20
A walk behind machine like that fails to give decent the great results because it tries to do everything at once.
Very well said, and very true!
encapman
Rick Gelinas
Walk behinds are also extremely inefficient due to the size of their vacuum orifice. They're typically very wide – perhaps 20" or wider. That wide vac shoe, coupled with a marginal vacuum does not afford adequate suction. As the machine gets pushed across the carpet – the machine squirts water into the carpet, the water gets brushed further down into the fiber, and then it gets extracted poorly. These large commercial "extractors" are a failed design from the word go. It's a recipe for wicking on CGD carpet!
AJR
Whatshisbutt
I’ll be honest I’ve been doing this for a long time. I’ve used Portables walk behind ride on extraction. I’ve done a little bit of encapsulation cleaning, but to be honest I just don’t see how the soil is removed. I get it it gets on the pad but after a while aren’t you just smearing dirt on top of dirt don’t kill me guys I’m just not seeing it when I’m pouring filthy water out of a portable or any kind of recovery tank. I can’t help but feel like I’m removing the dirt convince me otherwise please cause it seems to me like you guys are killing it with the cimex. These pictures are recovery water out of regular portables not heat dual vac 220 psi pumps . Also the halls are walk behind tenant 1610 dual crb with 220 psi pump and dual vacuum motors. I also run Titan 875 units . Use prochem ultra pack prespray and all fiber deep clean rinse. How does the pads remove the grit that breaks down the carpet fiber
Reactions: they live
How long does it stay looking like that? With a good encap product, you can use your pads to do the same as a Cimex. There's no denying that. It's not agitating as well as a Cimex.
AJR
Whatshisbutt
Does the cimex extract the grit? We extract those areas every 6 months . I’m assuming the extraction part of the cimex comes afterwards correct with a vacuum with a beater bar
Dwain Ray
I keep hearing the padder cult preaching less water, more agitation. But i don't think you can get much more agitation than an RX20 or much drier than a weighted drag wand
20201019_162938.jpg 20230907_140210.jpg 20221110_125239.jpg 20221026_113055.jpg 20241101_132040.jpg 20240130_125537.jpg 20230823_112949.jpg 20230414_144813.jpg
frank fratto
frank fratto
View attachment 134106 View attachment 134107 View attachment 134108 View attachment 134109 View attachment 134110 View attachment 134111 View attachment 134112 View attachment 134113
I have 2 rx20s. My Cimex will scrub better on cgd. Plus, no Dang
drag wand Dwain, if ya gonna drag
something, make it a zipper!
Dwain Ray
I've tried 3 other types of wands and go back to my trusted drag wand every time so far. When i went to school(iicrc classes) one of the things they preached was to differentiate yourself from your competitors and highlight that which makes you different . I tell my customers that there isn't much difference between the nylon/ polyester they walk on and the nylon/ polyester they wear . A washing machine uses saturation, agitation to remove dirt and centrifical foce to dry the fabric. And repeats the process to rinse. I do almost exactly the same. When a customer cleans clothes they first prespot i prespray with a hydroforce sprayer, next they put the fabric in the machine and add a detergent. I put the rx20 on the fabric and Frankenstein adds a detergent the washing machine agatates and spins to dry. My rx20 agatates and uses a powerful 47 roots blower to dry. The washing machine then fills again and repeats the process to rinse. I switch to a weighted drag wand and a rinsing agent and repeat the process too. The major difference between what i do and what my customer does is they put the fabric in the machine and i put the machine on the fabric. And that is what makes me different than my competitors. Now ive had competitors say to customers that they do the same as me,but they show up with a scrub wandand tell um they did it twice most don't believe um because of the two separate processes i do. Now if i have to do an estimate for a new customer i have before/during/ and after pictures on my phone to show exactly how much work im going to do. If price isn't there only consideration I almost always win the job. And over the decades of business i have lost a few regular customers to competitors because i couldn't get to um in a timely manner. For them ive adopted an attitude that has proven to be true time and time again that is "you can wait your turn or get someone else, and if you get someone else, next time you're more likely to wait. " the customers that have someone else and come back in most cases turn out to be the most loyal and most referring from that point on. As far as the drag wand goes i have so many and it is so much apar of my identity that it is prominently displayed as a part of my logo
20251015_150212.jpg 20171118_084625.jpg Magnet 2023.jpg 20221216_130400.jpg 20221216_130426.jpg 20250624_160906.jpg 20250624_160845.jpg Screenshot_20260221_132043_Gallery.jpg
frank fratto
frank fratto
View attachment 134115 View attachment 134116 View attachment 134117 View attachment 134118 View attachment 134119 View attachment 134120 View attachment 134121 View attachment 134122
Dwain,
You don't need to change one thing.
Keep doing what you're doing, unit you can't do it no more!!! 👍 👏👏👏
That’s the best analogy to carpet cleaning that I’ve ever read
And I know you do an awesome job but those drag wands make my back sore just looking at them. Lol
Reactions: frank fratto
Dwain Ray
I found that i could confuse and in some cases intimidate customers with big words and elaborate explanations. It took several years to come up with an accurate explanation that a housewife could understand and relate without belittling or dumbing down so much as to push them away and or make them feel stupid. When i take the time to use that analogy i try to be interactive by asking how they do laundry and explain my prespray and Emulsifiersand compare them to products they use.and what they and ther machine is doing and how similar it is to my process. Works great for this country bumkin
Dwain Ray
I do take that washing machine analogy a step further to set in customers mines that im the best choice after all that above is said ill continue by saying. For the most part carpet cleaner's come in two flavors. You have carpet cleaners and you have carpet rinsers. It matters less what there doing in the house and more with what's going on in the truck. All cleaner's pre spray, call it carpet shout. Carpet cleaner sprays down the "carpet shout" then his machine adds a detergent. He cleans and dries the carpet. Now if a carpet rinser was watching he would quickly point out that what is left in the carpet is a residue consisting of some of the prespray and some of the detergent. What he would do is prespray the carpet with the "carpet shout" then rinse it out with just water. I wink at the customer at that point and say it's kinda like doing the laundry and forgetting to add soap, are the clothes just as clean? Even though the washing maching cleans twice. Unlike most i first lay down the "carpet shout" then while my machine accurately measures in the "tide" i clean and dry the entire carpet with a rotary extractor. Then when finished i completely rinse and dry the entire carpet with a "special " weighted attachment so the carpet is first cleaned and dry then rinsed and dried. The only real difference between doing laundry and cleaning carpets is you put the fabric in the machine and i put the machine on the fabric. These housewives are now educated and if happy with the results turn out to be the best salesmen/ spokesman for my business. You can see it in comments on google and yelp they are excited and try to explain the total process
