Cleaning all carpet in a hotel
Amritgcalgary
Amrit
Role
Cleaning Professional
Years of Experience
2
I recently landed a hotel carpet cleaning gig and they are wanting to clean the carpets in the ballrooms, hallways lobby etc. every 3 months(about 40,000 square feet)
for the ballroom(16000 sq ft open area), I have been using a 20 gal karcher walk behind self propelled extractor(BRC 46/76). It did a decent job but i didn’t see a huge difference. I spot cleaned some of the stains afterwards with my portable and wand.
I pre sprayed the areas working one section at a time and then ran my karcher unit with just hot water in the fresh water tank. Should I be adding some sort of solution to the fresh water as well?
I was hoping I would see more of a pop on the carpets after extraction but I didn’t get that.
Maybe the carpets were still damp?
Do you clean the filter often, or touch the carpet with your hand to check performance?
Adding a rinse agent could help.
Do you have any advice on how to land these cheap hotel owners?
Or did you claw your way above the hotel to the corporate office?
I can’t give any suggestion on the karcher. I’ve never cleaned with one.
Which specific model did you use?
My advice is buy a Cimex and use Releasit products and go to town. Use fiber or fiber plus pads for the win. Every 3 months it will pay for itself.
sassyotto
Paul
although not a fan, if its every 3 months you could use VLM with Cimex or other whats ever popular now machine.
After thinking about it, if it were me, I would prespray an area, use a wide 20 inch Brush Pro to agitate and then your walk behind. Why? Because VLM, done the right way, doesnt save time.
Axel70
Russ Wooten
Role
Years of Experience
20
This is the answer! You will be amazed at the results. I use my Cimex at a senior living facility and they had always used Chem Dry or Stanley and they were blown away by my results.
Reactions: Kenny Hayes
