Cleaning all carpet in a hotel
Amritgcalgary
Amrit
Role
Cleaning Professional
Years of Experience
2
I recently landed a hotel carpet cleaning gig and they are wanting to clean the carpets in the ballrooms, hallways lobby etc. every 3 months(about 40,000 square feet)
for the ballroom(16000 sq ft open area), I have been using a 20 gal karcher walk behind self propelled extractor(BRC 46/76). It did a decent job but i didn’t see a huge difference. I spot cleaned some of the stains afterwards with my portable and wand.
I pre sprayed the areas working one section at a time and then ran my karcher unit with just hot water in the fresh water tank. Should I be adding some sort of solution to the fresh water as well?
I was hoping I would see more of a pop on the carpets after extraction but I didn’t get that.
Maybe the carpets were still damp?
Do you clean the filter often, or touch the carpet with your hand to check performance?
Adding a rinse agent could help.
Do you have any advice on how to land these cheap hotel owners?
Or did you claw your way above the hotel to the corporate office?
I can’t give any suggestion on the karcher. I’ve never cleaned with one.
Which specific model did you use?
My advice is buy a Cimex and use Releasit products and go to town. Use fiber or fiber plus pads for the win. Every 3 months it will pay for itself.
sassyotto
Paul
although not a fan, if its every 3 months you could use VLM with Cimex or other whats ever popular now machine.
After thinking about it, if it were me, I would prespray an area, use a wide 20 inch Brush Pro to agitate and then your walk behind. Why? Because VLM, done the right way, doesnt save time.
Axel70
Russ Wooten
Role
Years of Experience
20
This is the answer! You will be amazed at the results. I use my Cimex at a senior living facility and they had always used Chem Dry or Stanley and they were blown away by my results.
kingzm
king
Role
Years of Experience
1
Thanks everyone for the input — really appreciate all the insights.
Based on your experiences, it sounds like running plain hot water through the Karcher may be a big reason I didn’t see the “pop” I was hoping for. I’ll definitely look into adding a proper rinse agent or switching to an encap/VLM approach for maintenance cleans, especially given the 3-month cycle and large square footage.
The Cimex + Releasit combo you’ve mentioned seems to have strong support here, so I’ll be researching that setup further, particularly for heavily trafficked areas like the ballroom and hallways. In the meantime, I’ll experiment with better pre-spray agitation and a suitable rinse to improve extraction results.
If anyone has recommendations on specific pre-sprays or rinse agents that work well with the Karcher BRC 46/76, I’d be grateful to hear them.
kingzm
king
Role
Years of Experience
1
Axel70
Russ Wooten
Role
Years of Experience
20
Axel70
Russ Wooten
Role
Years of Experience
20
I have to say I use a Cimex with Releaseit DS2 and any tough traffic lanes I use Encap-Punch. For spots and stains, Stain 1 is great. I had a huge spill in a hall, someone spilled a full mop bucket full of very nasty water and left a 6 foot round dark stain. I used Encap-Punch as a prespray, agitated the stain with a Powr-Flite Multiwash and went over it with my Cimex as I did the hall and the stain was completely gone. I went back 2 days later and it was still gone. I've done commercial carpet everyway you can think of and telling you VLM is the way to get amazing results and save money and time. By the way the Releaseit products really are the best IMO, they will amaze you and your clients. Good luck
Reactions: Kenny Hayes
A walk behind machine like that fails to give decent results because it tries to do everything at once.
Great results rely on a well-balanced application of chemistry, temperature, agitation and dwell time
You've taken chemistry and dwell time out of the equation and unless that water is being heated somehow, you're now down to just agitation..
If it were me I would pre-spray a few hundred feet at a time, run just the agitator portion of that machine over it whether it's cylindrical or a circular ,and then go back over it with a acid rinse that has some clean ability to it, and extract.
Axel70
Russ Wooten
Role
Years of Experience
20
A walk behind machine like that fails to give decent the great results because it tries to do everything at once.
Very well said, and very true!
encapman
Rick Gelinas
Walk behinds are also extremely inefficient due to the size of their vacuum orifice. They're typically very wide – perhaps 20" or wider. That wide vac shoe, coupled with a marginal vacuum does not afford adequate suction. As the machine gets pushed across the carpet – the machine squirts water into the carpet, the water gets brushed further down into the fiber, and then it gets extracted poorly. These large commercial "extractors" are a failed design from the word go. It's a recipe for wicking on CGD carpet!
AJR
Whatshisbutt
I’ll be honest I’ve been doing this for a long time. I’ve used Portables walk behind ride on extraction. I’ve done a little bit of encapsulation cleaning, but to be honest I just don’t see how the soil is removed. I get it it gets on the pad but after a while aren’t you just smearing dirt on top of dirt don’t kill me guys I’m just not seeing it when I’m pouring filthy water out of a portable or any kind of recovery tank. I can’t help but feel like I’m removing the dirt convince me otherwise please cause it seems to me like you guys are killing it with the cimex. These pictures are recovery water out of regular portables not heat dual vac 220 psi pumps . Also the halls are walk behind tenant 1610 dual crb with 220 psi pump and dual vacuum motors. I also run Titan 875 units . Use prochem ultra pack prespray and all fiber deep clean rinse. How does the pads remove the grit that breaks down the carpet fiber
Reactions: they live
How long does it stay looking like that? With a good encap product, you can use your pads to do the same as a Cimex. There's no denying that. It's not agitating as well as a Cimex.
