100% VLM ???
frank fratto
Cleaning Professional
frank fratto
OK , not a knock, just maybe being realistic, there are limitations.
I love my VLM tools. Worx ,, original CCS OP Stepson
and ,
drink the Kool Aid time to time.
many years ago,, Vacaway claiming they are the best , newest at oily terribly soiled olefin!!! Heck yeah!! I'll try anything.
I forget which version it was back then.
Had a real test. Vacant home. some of the thickest , densest olefin you will EVER see. inch deep, could barely push my finger between the face fibers to get to the backing. White, TERRIBLY soiled. (old pics, with old phone don't do it any justice)
Got some of the aforementioned juice. And being realistic , realized the situation was not one for 100% VLM. I actually used the juice as a HWE cleaning agent first. Yeah foam, foam ,,, foam, I was anticipating that. and dealt with it. But , wanted to see if the touted magic juice of the day was IT! So performed the PITA foam filled HWE .
Quite a bit of drying strokes, BUT, I knew , plenty of that magic juice was down in there. just waiting to drag the oily, soils up into my absorbant bonnets spinning under my OP, leaving it like new.
NOPE!!!! traffic lanes still dingy. and NOOOOO, no blend mend! LOL! 😜😜
Again, meant for me as an experiment. Spent probably 5-10 X the time that area should have taken.
Next time?
Add a little ammonia with your mix and good dose of peroxide.
POP GOES THE WEASEL!!!
Rick J
rick Jones
Next time?
It was so long ago, I forget , but, I think I did use some peroxide. And maybe the juice was one that had it. the point being, wanted to see if indeed the stuff did what it claimed.
As , it was claimed to be the magic bullet , all by itself. for those oil loving , olefin, and poly fibers.
Reactions: frank fratto
frank fratto
frank fratto
I get it.
That's why I always bump olefin and poly fibers with ammonia and peroxide, I'm always bumping something 😂
Not a one jug guy!!!✌️
I think I'm going to order one of these. I had one way back, but I could never get it to prime. I think it was defective because I tefloned every thread and connection.
I had a problem with the quick connect on the spray wand. Got rid of it and have a permanent connection there. No more priming problems.
jeffexe
jeff
Hydrogen peroxide is Magical!!!
TM guys haven't realize the power of it!
Got to be very careful with it[ Heat 😮]
They don't use enough of it because they can't🤔✌️
PS. Nice Job!!!
That is what quality Battery sprayers are for. HWE knows about Hydrogen Peroxide and how to apply it properly when it is needed.
frank fratto
frank fratto
TM- guys cannot use hydrogen peroxide like VLM guys.
It keeps oxidizing at least 60 minutes if not longer?
You've already blasted it with 200+ degrees with your wand?
And if you guys truly know the true power of it ?
You guys would've been talking about it on this form for years. {Like every day because it is MAGICAL!!!🧙‍♂️}
Most TM- guys don't know how to apply it properly? They're too scared to experiment with it?
So you let some chemical manufacture add a little bit to their jug and they raise the price?
Most TM-guys can turn a wrench, but they're scared to death when
it comes to their own chemicals?
They've been told from the powers above , they're not smart enough😂
Just remember high heat and peroxide it's a no-no🤔
frank fratto
frank fratto
@Cleanworks @frank fratto @SteamwayPro what model of Worx Sprayer are you guys using and battery size? Have you made any upgrades like fittings, jetting, Lance length, etc? Post pics if you have them. All input is much appreciated.
Swani,
My go to is the 2 gallon pump zero.
It's slower and less volume" but I'm in no big hurry"
Worx, is my back up, I've kept it stock.✌️
Reactions: Living The Dream
SteamwayPro
George
I replace the wand with Multi Sprayer Wands. I buy the Multi Sprayer wands from Magic Wand. You need a Worx short extension for that. I buy them on Amazon. I use the 20v battery
Living The Dream
Swani
SteamwayPro
George
I have 4 wands that I use all with different teejets 8002 8003 8004 8006
I mostly use 8002 8003 but if I get into big rooms the bigger teejets 8004 8006 helps because you can move faster or if the carpet is trashed to put more down
Model # WG620 or WG620.1
Search that number on ebay for good deals. I buy them from Worx on ebay. Worx sells them on ebay refurbished like new and cheaper than amazon. They used to be $65
You will need more than one battery and of course you need to charge everyday if used
This is my set up. My draw hose is clamped directly to the inlet. It's the 20 volt model. The jet is a regular vjet screwed into a 1/4 inch open power wash fitting which the gun is set up to use. You can plug in regular power wash jets if you want. I'm using an 8002 jet. The one thing you have to be aware of is, these are designed to be mini power washers. This runs at 700 psi. It atomizes much more than a Hydra -force putting a lot of mist into the air. You may want to consider wearing a mask when using.
frank fratto
frank fratto
Frank let me know if I missed anything
Advantages for using the VLM Method
1 - NO petroleum needed
2 - NO TM blasting away disturbing the neighbors
3 - NO TM emissions polluting the environment
4 - NO doors open or security issues
5 - NO doors open allowing cold air in or warm air out Winter or cold air out and warm air in Summer
6 - NO doors open allowing insects in ( Florida Snakes Alligators Lizards )
7 - NO doors open allowing cats-dogs to get out
8 - NO close parking issues
9 - NO dumping dirty water issues
10 - NO van doors open allowing rain snow to pour in
11 - NO van doors open inviting thieves
12 - NO long Dry Times
13 - NO vacuum solution hoses covered with mud snow rain when working in bad weather conditions
14 - NO long set ups dragging carrying vacuum solution hoses from van to house 300 ft - 400 ft of hose
15 - NO maintenance issues
16 - NO ridiculous priced TM
17 - NO ridiculous priced TM repairs
18 - NO ridiculous priced TM replacement parts
19 - NO worries of TM water pump or solution hose freezing on a job
20 - NO heaters needed at night to prevent TM freezing
21 - NO worries of TM breakdown on job or difficult repairs on job
22 - NO worries about wicking
23 - NO worries of dull dingy looking carpet after drying
24 - NO large lease or loan payments every month for TM
25 - NO low profits because of high business cost
Disadvantages for using the VLM Method
1 - It's slower on Medium and Heavily Soiled Carpet
I love VLM !!!
George,
It was fun while it lasted! may or may not see you on the other side?
But if I don't keep up the good work , have fun cleaning carpets and good Luck!!!🙏
And to the rest of you guys, keep up the good fight!!!
May God bless you ALL and be Safe!!!🙏
SteamwayPro
George
George,
I want to leave this SHIT HOLE called New Jersey
This may be my last year in NJ and cleaning carpet
My friend wants me to move down with him to West Virginia he ESCAPED from NJ in 2023
Just a matter of time until I leave
I will see you on the other side !!!
frank fratto
frank fratto
Moved to the Villages in Florida you play and work and Retire all at the same Time!!! 😂 ⛳🎣🚣‍♂️ 🎾⚾🚲🏋️‍♀️
45 minutes from my house, crazy place crazy fun!!!
