16" or 22"?
Russ T.
Slater, IA
Russ Terhaar
I don't have a Prochem but it's going to come down to preference
I like the longer handle. I can keep my back straight without bending over.
Others might like being closer to the carpet with a shorter tool.
Reactions: Steve Lawrence
jcooper
IL
Jerry Cooper
Those of you that have the prochem stair tool.... 16" or 22" and why?
Do you wish you had gotten the other size?
It's a great tool, both lengths. It will never break or fail/last forever. I have the longer one(and always will).
However, not sure I would buy one again. The head is too small and makes a single tread/riser take like 20 strokes. The tools small head size makes it more work than it should be. At this point I'd rather use my wand and rip up my shoulder than fight the prochem and do 1k strokes on a staircase.
I'd try to find a larger/wider tool. He(hubby) will thank you!
Hawaii
x2... The head is too small, you minus well use your upholstery tool.... Almost the same size and you already have one.... I'd look into the PMF swivel Saigerized........
San Francisco, CA
Personal preference, as usual.
I use the 6" PMF , short stair tool, that many here do not like.
I find it much easier on my back, as I clean on my knees keeping my back straight. Much better maneuverability in a tight space. It also allows me to do much better cleaning of the stair's nose, which is always the most soiled and damaged part of the stair.
cleanking
Indianapolis, IN
Jordan King
22in, we had a PMF tool similar to what Saiger has and hated it. Really disliked having to use an adapter hose to fit the 2" and it was too light, didn't feel like it glided very easily.
We went to the Prochem about 3 years ago and all the guys really like it.
Although when I can I use a full size wand :headbang:
Ok so here is the deal-doe. :winky:
A wider head just allows fewer passes and the longer handle (34-36 inches depending where you measure from) less bending. The 2-inch barrel means no hose whips, just use your regular vac hose.
It is also lighter gauge material which also helps but because it is lighter you have to be more careful not to ding it up than with the PC one, which is pretty much indestructible.
It makes cleaning steps tolerable, while much easier on your back. Although you will get a steam bath from the heat kick back because you are now flowing some good heat. A great trade off in my opinion but some of my guys prefer the wimpy tool for that reason.
The difference is incredible. I cannot go back, the PC tool now feels like a toy for a boy!
Much easier to process stairs now with the larger tool. I still look at them with some reluctance but once I start cleaning I realize its no longer the chore it once was. :biggrin:
Our prochem is 2", the pmf style was 1.5"
While the PC tool has a 2-inch connection at the barrel it quickly drops back down in size past that connection.
Not true of the PMF. :cool:
PrimaDonna
Megatron
NorthEast, USA
MB
Thanks for the advice...but since we WON the stair tool from the Pro Chem Trivia contest (Laura contacted me, but hasn't posted it here yet) we won't be considering alternate tools. We just need to figure out which length of the Pro Chem will work best for us.
:eekk: ummmm yea...would you warn me before I put my foot in my mouth next time.
Sorry Auto! :cry: :redface:
This won't affect my chances at winning an Everest...will it? :smile:
Lets go Royals!!! :rockon:
I have a 36 inch and a 24 inch, I think the smaller one is easier to flip on the riser other then that the heads are the same.
Mine are knock offs
I had a prochem tool when I first went into business but preferred a 1 1.5 whip with a vinyl cuff liked to use my hand and the cuff to dry the bull nose.
Still if your taller get the longer one shorter get the smaller one.
Russ T.
Slater, IA
Russ Terhaar
A wider head just allows fewer passes and the longer handle (34-36 inches depending where you measure from) less bending, the 2-inch barrel means no hose whips just use your regular hose.
While the PC tool has a 2-inch connection the barrel drops back down in size past the connection. Not true of the PMF. :cool:
That's the one I want! I'll call Olson on Monday. Probably no glide for me though
I think they are hybrid. haven't had it happen yet. If you don't use a glide on your current tool you likely won't need one on this tool either. We have glides on all the tools so we ordered it from John this way.
Reactions: Russ T.
