PrimaDonna
Megatron
Those of you that have the prochem stair tool.... 16" or 22" and why?
Do you wish you had gotten the other size?
TIA...
TIA...
It's a great tool, both lengths. It will never break or fail/last forever. I have the longer one(and always will).
However, not sure I would buy one again. The head is too small and makes a single tread/riser take like 20 strokes. The tools small head size makes it more work than it should be. At this point I'd rather use my wand and rip up my shoulder than fight the prochem and do 1k strokes on a staircase.
I'd try to find a larger/wider tool. He(hubby) will thank you!
If you like using a wand you'll love the 2-inch, long handle dual jet. I'll measure it and snap a couple of shots in the AMOur prochem is 2", the pmf style was 1.5"
While the PC tool has a 2-inch connection at the barrel it quickly drops back down in size past that connection.Our prochem is 2", the pmf style was 1.5"
The difference is incredible. I cannot go back, the PC tool now feels like a toy for a boy!
We just need to figure out which length of the Pro Chem will work best for us.
Thanks for the advice...but since we WON the stair tool from the Pro Chem Trivia contest (Laura contacted me, but hasn't posted it here yet) we won't be considering alternate tools. We just need to figure out which length of the Pro Chem will work best for us.
ummmm yea...would you warn me before I put my foot in my mouth next time.
I wanted to wait for Laura to announce it, but then I saw the post going off track and needed to set you "helpful" guys straight!
Typical guys...don't answer specifically to what was asked.
That's the one I want! I'll call Olson on Monday. Probably no glide for me thoughOk so here is the deal-doe.
A wider head just allows fewer passes and the longer handle (34-36 inches depending where you measure from) less bending, the 2-inch barrel means no hose whips just use your regular hose.
It is also lighter gauge material which also helps but because it is lighter you have to be more careful not to ding it up than with the PC one, which is pretty much indestructible.
It makes cleaning steps tolerable, while much easier on your back. Although you will get a steam bath from the heat kick back because you are now flowing some good heat. A great trade off in my opinion but some of my guys prefer the wimpy tool for that reason.
While the PC tool has a 2-inch connection the barrel drops back down in size past the connection. Not true of the PMF.
I still can't believe you had Keith cut that wand down. Ahh Prochem Ti wand and you cut it half!!!!I'd ask for the shortened TI wand 14" head...![]()
How are you liking that tool?I'd ask for the shortened TI wand 14" head...![]()
