greentech said:You can split hairs about which does a better job.
I would say that the CRB is used to clean a lot more square footage . . .Erskine Allin said:there's a reason the Cimex is king of encRap sCampoo and NOT the CRB machines
and it has nothing to do with speed of production ...it's simply cause heavy rotary action with pads shears soil off the fiber better..period
Mattsfc said:What is a crb machine ?
Larry are you saying as a stand alone process or as one of the steps in the cleaning process?I would say that the CRB is used to clean a lot more square footage . . .
It takes a little time to get used to how to control side to side but it's really not bad. Even at that in a home you'd only hit traffic areas away from furnishings.Imagine how much experience a tech would need in order to run a 175 inside a custy's home without damaging something. Then, up and down stairs with that heavy piece of equipment and its only a matter of time before something bad happens.
