#20... SS370 build
other option...
I saw that one you posted in Vegas. Looked like a nice simple water tank.
Zee
Gotta be nice to Ray, from now on....Looks like they won't mess around with bad customers...hang them upside down in the shop and leave them, for others to see, as an example.
"yeah, you wanna return that? ok go ahead in the back drop it off with Sal and he'll take care of you..."
Reactions: Ray Burnfield
rick imby
Rick
What are you putting on the floor? Looks like slick hard plastic. Any flex to it for those worn out knees?
What happened to the hopped up Porty idea? I thought your were gonna be a VLMer...
that's the painted floor that will be Rhino Lined next week.
370
CFX w/ 1200psi docking station
175
RE
Cimex
EDIC Bravo
Vario OP
2 CRBs
Spinner and PMF hard surface tools
Zipper, DevPro and Mach12 wands
I'm a professional, don't ever forget that.
Ron K
Did you look at all at the Dodge? Larger volume, lower load height. Why not? It looks like a Lima been on Steeroids!
jwfoulk12
Justin Foulk
What made you decide to want to run out the side door? Just curious here as that's all I've ever known but not sure which way I will go for my next setup.
Tony Wilson
Tony Wilson
I've always run hose out the back. But if you always park on the street then side makes sense
Cleantechsk
Dustin
Ceiling mount the vac reel and mount the other 2 reels like how jim martin has his. ....
It's what I'll be doing with my transit
rick imby
Rick
370
175
RE
Cimex
EDIC Bravo
Vario OP
2 CRBs
I could not believe that you would step back to working with just a porty. Your new setup makes a lot of sense to me. I see you did not say which RE but i am going to guess you have several in Cali that you can choose from.
the 10" brush pro, the 360i, the Mach12...
all picked for the Gentlmanly approach..
but who knows
I could be running two Aerotechs out here within 3 years if my lady killer charm still works
Reactions: Mark Saiger
Before I went with extended vans I rear mounted a 405. Ceiling mounted vac hose reel crowding driver's side wall with drawer below. 12" wide pull out on other side.
This left lots of room up front out the side doors.
Downside: I felt it was slightly squirrelly for the boys to be driving, especially on the extended Ford, with its long overhang behind the axle.
I'm sure this set up is going to work great for you, but I would have pushed your reel since it's powered all the way back to the TM, and did something different with the solution reels..
Congrats on the new rig!!
I would like to get a one ton,but if it doesn't fit in my garage.. Are they still using the I beam suspension?
Tony Wilson
Tony Wilson
Plenty of room still for zipper, wand, chem shelf, fan and other stuff. Just no Cimex or back up Porty. But thats ok.... Were Truck mounted Steamers after all right? right? hehe
It will be Keith..
Notice the Rhyno isnt installed..
Reactions: Able 1
