Ross Buettner
Just wondering what everyone's preference for applying protectant is. I have a pump up sprayer and it's bulky and looks shady to people IMO.
Scotchgard is a fiercely protected brand name of 3M for a proprietary product.Brian R said:Scotchgard is a name like Kleanex
People call it that when they really mean protector.
If u use ur hf, u have to. Run vinegar through it. Then turn off ur chemical at ur machine and run it all the way threw till u see clear water. Just to apply protector with ur hf. This seems like a pain in the butt to me. Right or wrong?
Should u not run the acid rinse out? Or u just apply it with the protector? I would think mixing them. Would be wrong
I wouldn't use a HF sprayer, especially the "evolution" very inaccurate.
You can get the Omni or the Multi sprayer that has the van charger. I really like the corded sprayer just cause you don't have to worry that for some reason it wasn't charged when you needed it . Also you don't have the weight of the batt. to lug around.
I like the Multi sprayer over the Omni because the Omni is kind of big and awkward to carry especially when full, and takes up a bit more room in the van. The Omni has a 1/5 gal. bigger jug though.
Well now that's a good question. I would "think" that mixing an acid rinse with the SG wouldn't hurt a thing (that' why I've been doing it for the past 11 years). But, I'm no chemist.
Why rely on a pump and battery when compressed air works so well
Ruff Hewn said:Why rely on a pump and battery when compressed air works so well
cause soda fountain tanks are a PITA to use compared to 'lectric sprayers
so is/was that gOOfy azz garden hose HF you were blow hole'ing about a couple years ago
you're salesman, Brian, not CC'er
Stick to what you know about !gotcha!
..l.T.A.
