Click HERE for the EBay auction
HydraMaster and US Products Special Edition of the Triple Play Spotter
Discover a powerful idea in spot removal--the Triple Play Spotter. The Triple Play has three tanks: one for solution, one for rinse and one for recovery. So, now, instead of emptying your solution in order to rinse, you simply flip a switch. Chemical residues which cause re-soiling can be removed instantly. The large lift off recovery tank also lets you extract more spots before emptying. And talk about power. The Triple Play's vacuum motor is strong enough to extract spots using an optional light weight floor wand. It's also compact and easy to maneuver. In fact, it comes standard with 5-inch wheels and a foldaway handle so you don't have to go buy a cart. Spot the difference for yourself.
Removes chemical residue that causes resoiling
No need to empty cleaning solution just to rinse
Increased vacuum motor life
Allows spot removal using a lightweight floor wand
Power suction accelerates drying times
Large capacity extends extraction time
Lift-out tank makes disposal and cleaning easy
Improved reliability reduces costly down time
Power cord wraps on handle for transport
Easy to maneuver
No need to purchase a cart
Compact and lightweight of easy portability
Specifications
· Vacuum: Tangential
· Lift: 90-inch / 97CFM
· Pump: 55 psi
· Weight: 43 lbs
· Dimensions: 39" H x 10" W x 25"L
$599 Retail!!
Easy to maneuver
Specifications
· Pump: 55 psi
· Weight: 43 lbs
$599 Retail!!
