I was right...
This is a fantastic wand.
  1. Affordable
  2. 14"/1.5"
  3. One unplugable, drip and streak free nozzle, with no over spray
  4. Internal-easy peasy swap out- fit Glides
  5. Excellent extraction and drying
  6. Very maneuverable and a joy to use!
Needs a few tweaks to make it nearly perfect.
Really it's only drawback is its head height but with the shoulderless, triangle-shaped head it gets under more things than you'd think and for larger areas in most cases the furniture is not going to be an issue, where you would want to use a 14 inch wand..
Luky
Chicagoland
Mario
  1. Affordable
  2. 14"/1.5"
View attachment 128676View attachment 128677View attachment 128678
Not exactly a low profile. What other attributes are making this wand appealing? I'm trying really hard, is it lightweight? Is the head a bit heavier compared to the rest of the body? Is the weight of the wand less than seven lbs? I like double S feature, however bottom S is prolonged to make up for the angle of the jet . Jet is screaming for an extender
( or maybe the picture doesn't show everything)
I can't help it, I like my 13.5" Ti more with passing time. I understand that ugly duckling wands deserve to be loved too.
No offense.
No offense.
No streaking/clashing
No over spray
No drips
Hole or Slot Glides @ instant swapping
Lightweight
Equally as effective as a multi jet, but with less water ( 4 flow)
You know, everything your PCTI isn't or doesnt
