If it just started all of a sudden then it has an obstruction. You can clean the jets and if it gets better but not like new get new jets. Check to see if the jet bar is lined up still. It could have been bumped in between jobs and is now spraying a little cockeyed. You TM could have spiked on the pressure as already stated. You just don't realize it because you didn't change anything.
To see if it is just the pressure, hook it up as usual, pull the trigger while dragging it across the carpet and slowly turn the ball valve off. If the streaking goes away then you know it's your pressure. BTW you cannot run your wand with the ball valve partially opened for long because it will wear out the innards of the valve.
