RGH269 said:
I use mine for pre spray only, I have a couple of 3 gal pump ups for enzymes and sodium per carb, I wouldn't think it would work well for enzymes and out side the foam issue the per carb would lose its potency before you used it all. I know some guys have said they go through a 5 qt sprayer on a job I have always got a day or mores work out of one jug.
Depends on the tip and restrictor of your inline sprayer, plus the pressure and temperature of your TM.
I use 7qt jugs. One sprayer has a 4:1, and the others 9:1. That's means a
5qt jug puts down 6.25 gallon with one and 12.5 gallon with the others. The
7qt jug yields 8.75g and 17.5 gallons.
To add to the variation, at
lower psi a given injection sprayer BOTH puts down less total volume, and mixes it a bit stronger.
The reverse is also true, higher pressures put more total volume, of weaker draw.
At very high temperatures the draw percentage weakens until you will sometimes be drawing NOTHING at all until it cools.
Yes there's good reason for quite a bit of variation possibilities.
