Josh Almanza
- Joined
- Nov 22, 2016
- Messages
- 193
- Name
- Josh Almanza
What are some of the top rinses some of you guys believe are the best in the market based on performance, anti-wicking properties that also have cleaning capabilities? Thanks.
Water. Until proven otherwise.
I feel overuse of the wrong presprays would be the only reason to "need" a rinse additive.
I think I am somewhere around 9 years of just water..
I do amazing job cleaning carpet with my portable.Here we go AGAIN
With all the Powermax you use to use?...![]()
It should, what with all that Delimoline...
There's not as much delimonene in Powermax as some would think. There's probably just enough to give the smell of citrusIt should, what with all that Delimoline...
all the years I have used never once experienced a rinsing issue.....stuff just flushed right out...
Powermax has never had a problem rinsing out...
strong for me would be just 5 scoops. About ten ounces at 4 to 1. I think that rinses hard usually.I agree. I've used buckets of Powermax sometimes up to 3 cups in a 4-1 hydroforce and have never had a rinsing problem nor have ever seen rapid re-soiling rates on repeat jobs.
I'm not in the mood to descale my chemical injector every year, so I'm gonna stay away from ICE.
you southerners, I sware...
We've been using ICE since before it ever went public and never ever have had a plumbing issue.
But we do have on board softeners.
But take a truck thats spooged up with hard water build up and run ICE and you'll be giving it a colonoscopy for a few jugs worth.
No rinse is going to de scale a machine with last step.
