AshleyMckendree
Ive built yet another dual blower setup for my Direct drive Ambulance, I think this is the third dual blower setup my father and I have setup over the years.
Its a roots 45 and a roots 36, I thought about using a sutorbilt #4 in place of the 36 but its mounting feet are cast and I wanted both to be horizontal.
The main reason for doing this is so we can run the machine at slower speeds and still maintain a decent CFM,
The problem im running in to is at lower speeds (Van @ 900rpm, blowers are spinning at 1800rpm),
It 'sounds' like plenty of cfm at the wand, more so than just one blower at 90/100% blower rpm, but not very much lift.
At what rpm do I need to run these blowers to achieve there full lift capability?
And if I water inject the blowers will they reach higher HG lift across all rpm ranges?
P.S. This thing makes my glided GreenHorn SCREAM when I set the RPM at 90%, at the end of 200ft of hose, so loud it freaks out my customers... im afraid to even try 100% rpm!!
How do you Vortex guys deal with a loud wand??? I imagen I still don't have the CFM of a V!
