- Joined
- Aug 11, 2012
- Messages
- 13,372
Haha maybe when I slammed on my brakes though.We're you by chance sitting in the front seat when that dude punched your face in 1.5 inches?
Thanks Lee I got that part. Is there a sequence for aligning it to the pump and blower? Got a little vibration yet.The whole driveshaft looks to have moved back half an inch or so?
What's the alignment of the front, clutch, pulley?
To start, the pulleys at the back are at the right spot on the drive shaft. Use that as an index. I'd loosen the middle and front shaft supports and push the shaft forward. I'd need to see a picture of the front to go further.Thanks Lee I got that part. Is there a sequence for aligning it to the pump and blower? Got a little vibration yet.
I'm going to descale it after I replace that hose that runs underneath the pump to the regulator.
Cleaned 2 couches today that took 2 hours then it blew at my daughter's cleaning some concrete. Temps were over 240 both jobs.
I was surprised it was only wearing the belts. There is black rubber spray on the tensioner. I wonder if some of the rubber I had been smelling was coming from that. After the front belts broke I assumed that's what it was. The belts were put on end of last year. No noise. It hasn't been run a lot.To start, the pulleys at the back are at the right spot on the drive shaft. Use that as an index. I'd loosen the middle and front shaft supports and push the shaft forward. I'd need to see a picture of the front to go further.
I'm surprised all your belts didn't come off. You had to HEAR something very wrong.
Saiger" data-source="post: 4704736" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">I will check that out today thanks Mark.If vibration, also check the fan clutch. Grab it and shake up and down. If a bunch of play it needs replacing.
Butler uses a non thermal aftermarket clutch with a slight bit of machining. You would need to order from them thay fan clutch
if your driveshaft is going I would think you would hear it rumbling and maybe even feel it. Like a wheel bearing in your car. At least on my old one that was the case. I still have a spare shaft sitting waiting. BUT the truck is long gone!!! LOL. I used to like being prepared.I was surprised it was only wearing the belts. There is black rubber spray on the tensioner. I wonder if some of the rubber I had been smelling was coming from that. After the front belts broke I assumed that's what it was. The belts were put on end of last year. No noise. It hasn't been run a lot.
Chip thinks I need a new driveshaft.
Just got back from picking up dinner and still had the cover off. It was making quite a bit of noise. I was just going to post about it.if your driveshaft is going I would think you would hear it rumbling and maybe even feel it. Like a wheel bearing in your car. At least on my old one that was the case. I still have a spare shaft sitting waiting. BUT the truck is long gone!!! LOL. I used to like being prepared.Got a clutch as well. !
You must have kicked in the afterburners when stepping on the gas to have shifted it to the rear like that. !!!!![]()
It's a 2010 gmc. ? If nobody knows ill call butler tomorrowwould love to, but doubtful it would be right for your rig. really old. I had gotten them as a just in case long ago but never used, and the truck went down and I junke it. It was for an older 91 GMC.
he may not realize there was a bracket holding the front end right next to the clutch somehowOMG
A picture of the FRONT OF THE SHAFT, AND CLUTCH AREA.
Are you doing that on purpose just to get Lee's goat? LOL
another thought, if indeed the driveshaft I have would work and I would get it to you which is I would I think do you have someone qualified to install it for you or are you going to do it?Just got back from picking up dinner and still had the cover off. It was making quite a bit of noise. I was just going to post about it.
Want to sell the shaft and clutch?
I said the front was fine. I know the bracket holds it in place but wasn't sure if breaking those bolts loose would move anything. I didn't think so but have had a run of bad luck so just wanted to make sure. It was easy enough to to get it back into position.tough luck so was just looking for confirmation. he may not realize there was a bracket holding the front end right next to the clutch somehow
Butler said it won't work but the cost of a new one isn't horrible.another thought, if indeed the driveshaft I have would work and I would get it to you which is I would I think do you have someone qualified to install it for you or are you going to do it?
