with just one finger.....
It is a 2000 PSI hydraulic/water metering valve....it is color coded for the pressures...
green being the lowest ( about 200 PSI ) and gold being the highest...so the highest will be what ever I set my regulator to at the truck....
I clean with about 350 PSI..but now and then I will hit a bad area that need some extra work or more flushing...so if I set the regulator on my machine in the truck to about 500/600 PSI..Then I can just take my finger and bump it up to the next color..and when I am done just run it down to my normal cleaning pressure/color......no need to take your hand off the trigger...
Got the idea from ...Studebaker and just ran with it a bit......
