I only used it a couple times but wanted test some equipment I had laying around because I am getting some high rises. Plugged it in, it turned on but no suction. The whole insides fell apart while sitting on a shelf in a cool dry storage area held at between 60-75 year round.
I decided to take it apart. I didn't any tools it was two bolts on the side that slid off easily with my hands . That is all it took is two bolts
Next I pulled the top off and all the pieces were laying on the bottom with a piece of styrofoam(?). If you look the clamp isn't holding anything down. The little surface rust indicates that the intake fell off along time ago
Here is how the vac was set up with the intake, nice and sturdy as you see
this is the top of the line booster. As you can see it still has plastic on one wheel and I never attached the handle. No rust anywhere. No abuse
here is the picture of the first bolt inside
here is me unclamping, hahaha
