- Joined
- Oct 25, 2016
- Messages
- 3,234
- Name
- Swani
Today I added 3 gallons straight vinegar to my empty water box and hooked solution line from fresh water QC to solution line QC and ran for 10 minutes. How long should I leave vinegar in my machine?
I just did a few searches on the forum and just winged it.I'm curious too..
Who told you to go about it like that?
A filter would have been a good idea! I'll keep that in mind for next time. I'm thinking of leaving the vinegar in over night? Do you think that will be ok?I do the same thing with mine. I usually run it for 10 to 15 minutes. I use a filter so that I don't recirculate junk back into my system. Amazing what comes out.
Personally, I wouldn't do it. Acids are a great descaler but are corrosive. I usually flush with clean water after descaling. Others may think differently.A filter would have been a good idea! I'll keep that in mind for next time. I'm thinking of leaving the vinegar in over night? Do you think that will be ok?
Saiger" data-source="post: 4502015" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Vinegar isn't going to really do much...
A real Descaler is really needed to get the crud out from minerals and build up....
This is for our Butlers...but each machine would have a procedure....
10 percent acetic acid, or double strength vinegar. Table vinegar is 5 percent, pickling is 7 percent, cleaning is 10 percent.we have soft water here as well . We also fill our water tanks thru a 50 micron filter before it goes in the machine . So we usually use a descaler every 6 months on a closed loop . let it sit for 15 minuits and then flush .. seems to work well for us . maybe i will switch to a vinegar too . What kind of vinegar is best ?
