The drying agent in Judson's rinse (alcohol per Les) seems to be effective. Does any of it evaporate out of the solution if the rtu jug is left open for a day or two?
A local distributor sells an additive called Dri-Vapor, which is probably mostly isopropyl. In my experience, it leaves carpet stiff and sticky when used per direction. (Judson's rinse does not.)
Anyone ever experiment with adding isopropyl or another drying agent to rinse?
