Exposed my Zipper
jack zerkie
Had a large clubhouse to clean 15 K. started with my roatry dri machine, this was okey but the head bumps over the uneven glue down and the power cord makes it harder. Then I tried the Zipper seems to glide better over the cpt. and no power cord. Using the Zipper is like learning to dance to the music and I have two left feet. I play the drums but can,t dance, but once you get a pattern, just keep going.The Zipper made it easy for open areas and quicker I like the end results, and hope to get better using it. jz.
Jack how did it clean and what kind of sq/ft did you average cleaning at a comfortable pace?
jack zerkie
The Zipper cleaned as good as the rotary dri machine and moved easy on CGD. I had some areas that were new concrete and not even and the Zipper cleaned better then the rotary.Both units were about the same for drying times. The roatry unit is harder going from side to side. The Zipper back and forth motion is easy,once you get a pattern.I think the roatry unit will be for sale very soon.
Bob Foster
Jack, what psi did you run the zipper at?
Did you go through lots of water?
Jack;
Nice report.
The Zipper is a machinist-built extractor head.
I tried it with good results, at the last Connections show.
John Watson
Waiting to hear from Ernie G and Stevie F about their sperences wid it.
My Helen has to wake me up nows and agens for almost fallen asleep dancing wid my Miss Wanda!!
jack zerkie
Bob really can,t tell how much water I used garden hose to my Cobb 2045 unit, but the recovery tanks are 90 gals new roto mold tanks and emptyed them every hour.
I dont clean very many large jobs and didn,t get the auto pump out, just mite add it down the way.jz.
Jack;
One additional positive factor to consider:
With the Zipper using that much water, the Heat Exchanger actually operates more efficiently.
It will maximize the total BTU's transferred to the carpet,
even though the actual temp will be less.
joeynbgky
Joey
Larry............ why dont you carry the zipper for your customers? you should
steve frasier
I did several jobs with the zipper yesterday
it is jetted @ 10 flow so I used about the same amount of water
it took a littler longer then using the glided Ti wand (edged with a wand first)
I overlap a lot and did a slower dry pass, because I have so much vacuum the zipper kicked my ass (all plush carpets), I think for the blower I have I might need a vacuum relief on the zipper
only used it on some bigger residential houses, no commercial yet but really not the big of a deal to work with in a house
doesn't fit under things or into some corners like the Ti wand will so will have to have an edging tool
carpet was drier to the touch then when the Ti wand is used
like the sight glass
not a bunch of steam all over the place
seems quality built
did some cut pile nylon today, easy to push and pull, the zipper sure does make the pile stand tall
