boazcan said:
Jim Martin said:
what jet and orfice combo are you running...
I have the 3 long and 2 short with the smallest orifice @ 500psi (but on a 250 ft solution line). My greenhorn runs much more flow at 15 @ 700 psi.
get yourself a 25 foot 12/3 extension cord...that is going to be the best for this machine...
I get the ones that are lighted at the female end...much better to know you have power there...
keep the smallest orfice in and drop your pressure to about 350 to 400...
this machine will clean faster then any one out there...but...
you still have to pace yourself on the different types.....
you want to slow yourself down on the thicker type carpets and give it enough time to do its job...
you can pick up the pace on the commercial grade type nylons...
and even speed up some on the CGD...
it will take a bit to get use to but once you find the sweet spot..you will see what I mean...
