May 29, 2012 #1 miksar Supportive Member Joined Dec 1, 2007 Messages 287 Location Florence, Az Name Mike Fent I can't remember if I have run across this before, anything special to remove this from nylon carpet. Fresh spill, supposedly being kept damp. TIA
May 29, 2012 #2 J Scott W Member Joined Oct 16, 2006 Messages 4,061 Location Shelbyville TN Name Jeffrey Scott Warrington Finger paint is rather easy, especially when it is kept damp. Scrape up whatever you can with no water or chemical. Then clean with heat and plenty of water. If any remains, treat with your PIG.
May 29, 2012 #3 Able 1 Member Joined Apr 12, 2008 Messages 6,469 Location Wi Name Keith "Invade" by DCS or DSC (not sure) is the stuff I use for an all around killer solvent. Gum,ink,works AWESOME on filtration soiling, any any other spot Fels won't remove.
