Blue Monarch
Kohler 20HP motor with 100 hours.
Is there any reason not to switch over to full synthetic right now?
Kohler 20HP
Michael and Dan;
You are giving out incorrect information ! (Many times the internet is NOT up to date)
Hopefully Dirk has received better info ??
Since temps in Vans now are quite hot, this is the correct info from Kohler:
If your TM manufacturer is not insisting on using 20W50 oil,
your engine life is at risk over 50' F.
Kohler recently changed the oil viscosity specs . . .
right after a MB member accused us of causing a main bearing failure.
Also automotive oils have decreased the zinc content to prolong catalytic life (per the EPA).
This causes MORE wear in our TM engines.
We carry 20W50 oil , with the additional zinc.
Larry
. Some will get long hrs but these engines aren't designed to run in an enclosed truck. The also aren't designed to last lots of hrs. The longer your jobs tend to be the hotter and more stress it puts on the engine shortening its life. Just my belief. The synthetic oils handle high temp better for longer periods without breakdown. Stick with what the manufacture tells you just don't expect a long life. Coo the engine for a couple minutes after every job.Ok, so all you smart ones: Now what the hell would you start using in a brand new Honda air cooled that goes on the tm next week?? 20-50?
I have always used 10-30 in the tm. (honda manual called for that...and yes it seems to be done at 2100hrs. Oil and filter was religiously changed at every 100hrs as the manual called for)
Dan;
Also Larry, 85-90W gear oil is way to thin for TM blower service.
Larry
Larry
One reason guys are getting the life out of their motors is that they are getting enough airflow to keep cool
Dan;
In order for all of our TM engines to be approved for warranty status . . .
factory reps must check the engine under full load in a typical van installation.
Our TM's are built with open design with the engine close to the side doors, and no shrouding of engine air flow.
Even with those cooling advantages,
the factory testing at our plant always showed oil temperatures on the high end of their acceptable range.
We started using SAE 30W after the recommended break-in oil interval.
Now we have switched to 20W50 oil, that has a complete package of additives including zinc for scuff protection.
The regional Kohler factory training service rep told us that Kohler multi-weight oil is NOW 20W50 with a full additive package.
Larry
Does one machine or company in specific have a reputation of "longest lasting motor"?
