Larry B
Can the electric fuel pump that supplies gas from the van tank to the motor on a slide in be replaced with any 12v fuel pump from an auto store or are they to big?
.... while eating raw fish
Larry;
The fuel pressure on that fuel pump is too high !!
Flooding could be the result. .
Proper pressure is 2 to 2.5 PSI. .
Larry
All you need is something like this.
http://www.summitracing.com/parts/MRG-42S/
You can get one at any auto parts place.
The pump thats on it now wont even fill the filter with gas. The filter is never more than half full of gas and when the machine is running wide open it cant keep up.i would not recommend that particular fuel pump. I've had 2 premature failures with it. It does come in a 2 PSI version.
You can also buy an adjustable fuel pressure regulator if your existing fuel pump is 5 PSI or greater.
Go to NAPA and get a better fuel pump.
I agreeLarry;
Larry
