vincent
How many times do you try a spot before you give up?
Royal Man said:If you are talking about red removal it is only for synthetic stains.
Don't mix the product and it will last longer. Just put a spray nozzle into each bottle.
If you use a steamer (instead of an iron) no towel is needed.
It really is not transferring the stain.
(Even if some is going into the towel)
The spot is made invisible to the eye by a chemical process that is accelerated by heat.
You can still find B&D steamers/strippers on E-bay even though they quit making them in the 80s
Here is one from the UK : http://www.ebay.com/itm/Black-and-Decke ... 4ab7dba177
Royal Man said:For those of you that are still using a freaking old fashioned iron
First one gets it. Buy it now $69.95
http://www.ebay.com/itm/Black-and-Decke ... 484565dde9
Able 1 said:Royal Man":2leo8a5p]For those of you that are still using a freaking old fashioned iron First one gets it. Buy it now $69.95 [url="http://www.ebay.com/itm/Black-and-Decker-SteamWorks-Wallpaper-Stripper-/310401949161?pt=LH_DefaultDomain_0&hash=item484565dde9 said:http://www.ebay.com/itm/Black-and-Decke ... 484565dde9[/url]
SOLD... Is there any way to fix them when you run regular water through them?[/quote:2leo8a5p]
No need to worry about that if you use the one I posted.
floorguy said:yup they are awesome....same as the one i posted from HD....
then you can hit multiple spots, and leave it in one place
