Feb 22, 2012 #1 Becker Member Joined Oct 8, 2006 Messages 7,359 Location Snohomish, WA Name Becker Before I try I figure I will ask.. How is it removed?
Feb 22, 2012 #2 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb Becker; Pull the valve covers off both heads. Pull the rocker arms and pushrods. Remove the crankcase cover off the back of the engine. Camshaft gear and cam is accessible. Larry
Feb 22, 2012 #3 Becker Member Joined Oct 8, 2006 Messages 7,359 Location Snohomish, WA Name Becker Yeah. I have the cam gear exposed. Have the valve covers off. So if I pull the push rods then the cam will just pull out?
Feb 22, 2012 #4 Becker Member Joined Oct 8, 2006 Messages 7,359 Location Snohomish, WA Name Becker Thanks for the help. I loosened the rockers enough to move them aside. Pulled the push rods. And the cam pulled right out. I have a new cam and new carb on the way. And yes. I will clean and reclean the inside of the block and replace filter before firing it up. But the machine just flat died. So I'm sure all the f Platic peices are in the bottom of the block. Would be nice to get another 3k hrs out of it. Maybe more as it will be driving a propane heat unit.
Feb 22, 2012 #5 Larry Cobb Member Joined Oct 7, 2006 Messages 5,795 Location Dallas, Texas USA Name Larry Cobb 3,000 is good service for the Honda engine. Another 3,000 is very unlikely, without a complete rebuild. Larry
Feb 25, 2012 #6 Becker Member Joined Oct 8, 2006 Messages 7,359 Location Snohomish, WA Name Becker Ok. To be honest. Another 1000 would be great. 1500 awesome. But who knows. All else looks great. I've been great about oil changes. Engine is going on a propane unit. So less back pressure might help her along. Found cam for 100.00. 10.00 shipping. Worth the cost to see.
