Hey,
To winterize the machine it says to add anti freeze to water box. Can I just run the pressure pump with no water hooked up to empty it? I thought that would damage the machine... How else would you empty a waterbox?
The water box has no drain hose or valve(it does look like it has a drain plug, in back very hard to get to). I know some machines have a valve on the front to empty the box. Would this be a good thing to add? Seem to me, I could just get rid of the drain plug(if that's what it is) add a fitting, ball valve and hose... Bam! But is it something that's needed, will it make winterizing easier?
Thanks for the help...
