daniel@procarpet
- Joined
- Sep 7, 2008
- Messages
- 3,797
Just curious.
Able 1 said:I wouldn't do it unless you sucked water through the blower and leave it sit. The blower is so hot the moisture just dries up just cleaning carpet.. I think WD-40 leaves a residue on your heat exchangers that makes it more important to clean them regularly(since they will collect more dust)..
danielc said:Able 1 said:I wouldn't do it unless you sucked water through the blower and leave it sit. The blower is so hot the moisture just dries up just cleaning carpet.. I think WD-40 leaves a residue on your heat exchangers that makes it more important to clean them regularly(since they will collect more dust)..
I used to do it EVERYDAY. I haven't sprayed anything in it in like 7 months. :shock:
Only because I can never find a damn straw.
I'm going to hit it tonight and will get back on schedule.
I always let the machine run for a bit to cool machine down and blow any moisture out.
Able 1 said:danielc said:[quote="Able 1":2jpb2zzt]I wouldn't do it unless you sucked water through the blower and leave it sit. The blower is so hot the moisture just dries up just cleaning carpet.. I think WD-40 leaves a residue on your heat exchangers that makes it more important to clean them regularly(since they will collect more dust)..
danielc said:When I clean my heat exchangers out I doubt I will lube blower unless I am storing it for extended period. I think it does contribute to the exchangers getting dirty.
I would like to clean my blower out, but I would have to pull exchangers out and I don't want crap going all over my truck.
How would you clean blower out on prochem everest?
How important is it to lube blower with wd-40 etc?
Bryan P said:I spray mine at the end of every day, with WD-40....Only because my Tuthill TI850 blower is somewhere around $7,400.00 new.
Thank you Shawn!
Ross Buettner said:I used to use Marvel oil on siezed 350 chevy engines if that tells you anything
Able 1 said:danielc said:When I clean my heat exchangers out I doubt I will lube blower unless I am storing it for extended period. I think it does contribute to the exchangers getting dirty.
You will want to pull your heat exchangers and run fresh water through it....
danielc said:Able 1 said:danielc said:When I clean my heat exchangers out I doubt I will lube blower unless I am storing it for extended period. I think it does contribute to the exchangers getting dirty.
I know this, but I don't want to have crap blown all over the back of my seats and EVERYWHERE.
I could get some plywood and block off the cavity where the exchangers sit.
I am going to do it over the Christmas break if I ever slow down and the weather permits.
