Jim Martin said:
you can remote start anything....you can even teach it RPM's...but you are looking at money to remote start it and ramp the machine up and down...
just not worth it....I cant think of one time once I got the machine up to running speed that I needed to run out and turn it up or down....
normally once it is running I never have to touch it until I am done...
I guess we clean different.
I clean on medium running the wand most times. I always turn the machine and heat down while doing stairs. Also when I run a rotary I turn the machine and heat down when dry stroking which really only takes a few minutes. Just little things like that. If I spray and clean upstairs, I will turn machine down to idle while spraying the downstairs and then reset once I start cleaning.
