If you could only have 1
If you want a tool for residential, and decide on 175, at least go with rotovac
360. You can change the head for 175 effect. Light to carry up those steps.
But still, crb and rotovac is killer combo. I Do Not have a Dev., Board du jour, or not,
but I’m guessing that’s a tool to have.
What some people don't seem to realize, is that a RV 360 with a brush head can actually be used to scrub with, without flushing. You can activate the brush only to scrub in your prespray, then pull the trigger and start flushing it out. Very effective.
Bob Pruitt
Robert Pruitt
I like my CRB. Soft brushes and slightly harder brushes...for really dirty tile. I use the crb on almost every job I do.
I like the 10 inch if you can only afford 1. I use the 10 inch to scrub stairways by removing handle...very easy.
Not sure why you would only buy just one or the other though. 175's can be found in almost every pawn shop...very cheap.
Meter Maid
The Undetective
All I know is my CRB doesn't cut through greasy traffic lanes on this shitty polyester frieze we see around here all the time.
A rotary or OP (except a Trinity) cuts right through those lanes.
BTW, a 15" Cimex only weighs 84 lbs. Thinking about getting one.
Reactions: Deke Hatley
The motor is too small on the 15. It doesn't work as well with the more aggressive pads and you can't buy them to fit. Unless things have changed.
Hack Attack
Dan
If I had techs whose judgement/skill I didn't fully trust I'd say crb every job so you look like you're doing more.. but not every job visually benefits from agitation. Fact
DAT
Bill Cheryl
CRB... But i will mod my 175 with handle and larger wheels to see if that will help.
DAT
Bill Cheryl
It will be the same weight plus the handle.
Weight is part of the concern, it's safely carrying it around if lifting is needed. The 175 isnt exactly carry friendly. Its meant to be wheeled around.
Reactions: Trip Moses
Trip Moses
IMOL
Trip Moses
The nylon handle on my Hoss 700 works very well
Hack Attack
Dan
the handle is great for getting it in and out the van, I try not to carry any agitation tool upstairs if I can help it.
I've never put bigger wheels on one, but I remember my Dad had one he modded that did
Reactions: DAT
Well, I got $1500 in the mail today.
91813
“Mytee sent me a pos the should have never made it by QC but they told me how to fix it. Awesome company” - R. E. Ta..
