Fill it with water, chances are you will have a brown spot when it drys. Vapor steam and suction with the end of a vac hose usually works.
Wet towel. Hot iron. Steam and use a bone scraper to lift the pile.
I answered a customers issue with this response when he asked about removing furniture stains underneath a bedroom dresser.Cover with furniture.
View attachment 83773 View attachment 83774 I use a wallpaper steamer
Eternal optimist? The way you layed it out, there's just no hope. That's just the way it is and it's gonna stay like that.Takes a lot of time to fix a long area, so unless they client is willing to spend the $$, these heat treatments are not practical. And there's a difference between a crush by a light furniture or something really heavy.
All the heat methods rely mostly on the fabric's heat memory and yes it will spring back up, but it does not do much to the glue layer and or secondary backing and nothing at all to the crushed pad. n my experience most crushed pads never fully recover.
You can use lots of extra heat to soften and then pull up (straighten) the glue layer and secondary backing (if through lots of water you need to consider how much damage is done to the latex/clay layer) and if with steam is the client willing to pay for the extra time. However many times eventually it will go back to the way it was (though less) once its exposed to weight and traffic, because there's nothing beneath that supports the tufts long term.
As an eternal optimist I present it to my clients that they will not have to guess where the furniture goes back.![]()
After pre-conditioning as I enter the room I fill depressons with water from the Wand the hotter the better then clean my way out when I get to the wet spot (ad wise ass comment here) I take my glide off and agitate with edge of wand and clean as usual. Works for us.
lolCover with furniture.
Same here, I have 3 b&d steamworks and 3 namcos. $1 per time I set down a steamer.i use our B&D pretty fast and easy
Depends on the TM.TM water can gets hotter than a tea kettle.
