move ins and move outs,water/pet emergencies....who else has their carpet cleaned in that type of weather?
people that don't live in the south and left coast TwinkieLand , Cupcake
Coop, we we're out in single digits a couple weeks ago.
it was 7 or 9 degrees when the van left
when it gets 5 below , I start thinking about rescheduling .
It depends on the job's set up more than anything .
we've worked in as low as -12
I reschedule more jobs due to
bad snow storms than cold
Start your TM in the morning.
cover or partially cover the vac port enough to put a load on the blower (appx 11-12Hg or so)
BTW, a lid off a powder jar works great..
let it run like that for 10-15 minutes .
Your van interior and all gear in it will be warmed up.
Wand, sprayers, vac hose are set up first .
Then fresh water line (if used) let it trickle as you hustle in the solution line .
Put a naked QD on the sol line and stick the end in the vac hose
get both sol line and fresh line plugged in quick and turn on the pump
On long set up jobs (long runs outside in the cold) we'll pull the whole sol reel off and walk to the farthest point and roll out to the truck
after the first job of the day, everything is hot..and hopefully the morning's temps have warmed up to at least hi-teens
..l.T.A.
