NobleCarpetCleaners
- Joined
- May 16, 2010
- Messages
- 1,191
- Name
- Noble Carpet Cleaners
Learned a little today about Kohlers and where they really show wear at 1,500+ hours. At 1,800 hours (4 months ago) if was billowing smoke and bogging down under a load. Got so bad I purchased a new one.
Got around to inspecting the old one on my bench. Pulled a head. Flashed some high intensity light on the valves and say light peaking in both ports. Carbon deposits under the valve cover around the exhaust valve stem, a little around the intake valve, pool of oil on top of the cylinder. Pulled the valves and measured stem/guide clearance within tollerence but the valves wern't seating properly.
Cleaned the seats, valves and head free of carbon deposits. Used some prussion blue to see how much seating was taking place. Not bad. Lapped one valve already with reg. and fine grit and now have a perfect blue transfer ring around the seat.
Machine shop wanted $185 per head to cut the seats and grind the valves. They don't even offer lapping and assemble for that.
My investment will be two head gaskets and a intake steam seal. I have a way to test it under load and will report back if she holds under load. All this time I had the feeling the piston and rings were fine. I'm hoping there's 500 more hours (maybe more) left in her. I have a roots 36 I want to build back into a spare machine.
Anyone else out there performed a little valve maintenance and kept going on a similar engine?
