-JB-
- Joined
- Oct 26, 2006
- Messages
- 5,387
- Name
- JB
Any all 'yall using the new Rotovac CFX yet?
Waddya think?
Waddya think?
AshleyMckendree said:I like the Idea.
Now if it was designed by greenie, it would be a 2 cubic foot TM on wheels :shock:
Edit: Just plumb it 2.5 inside and out, run 25ft 2.5, and have a little giant outside and it would be a mini Vortex![]()
JB said:Any all 'yall using the new Rotovac CFX yet?
Waddya think?
PS I hear that Dennis (DurrMaid) who designed the machine got ACED by RotoVac??? if so liars CHEATS and hucksters will be thinned from the hurd!!! .
i see where he has his new machine out on the market now
It's a High Flow system, there is no way to add, nor SHOULD ya need solution w/high flow. The fresh line hooks up to the faucet then runs DIRECTLY to the tool of choice as, there is no chem. or pressure pump, and unlike the SD, the wand or the RV acts as the solenoid/trigger, so one less component to deal with, or break! :wink:How would one add a rinse to it? I only saw a hook-up for a faucet, nothing else.
It's a stand alone.Can it be used as a "power booster", or as a stand alone? With only one cord, it must have 2 small 2 stage motors in it, fine as a booster, pretty wimpy as a stand alone. I didn't see any hookups for another machine, so I'm guessing it's a stand alone.
Small jobs would do okay, fish tanks 'n' the like, but I agree, for big floods get the right equipt.! Get a flood pumper.And how about that pumpout...I think it's rated at 5 gpm....maybe fine for carpet cleaning, no way would that be ok with flood work. Just my opinion.
$2195. w/hoses and wand;(just the CFX)How about a price?
Nah Uh! No pump, you haven't cleaned till ya cleaned w/High Flow Baby!How about a pump? Again, I didn't see one...do they use standard city water pressure? If so, that sucks.
They claim it doesn't :roll: in fairness the pump switch is proprietary, un-like the SD switch, A BILGE PUMP SWITCH from Boat US!does it have foam problems on the pumpout side??? i know when i had a Demon FOAM was the great equalizer. how will the foam issue be handled by said unit???
And crud can tend to build up on the SD switch too again allowing it to fail to pump, causing blow-back, and leading to pre-mature vac motor failure. But i generally use a, "no soap" cleaner, so I never have many issues w/that anyway, don't do a lotta nasties.Here anything new on this issue?PS I hear that Dennis (DurrMaid) who designed the machine got ACED by RotoVac??? if so liars CHEATS and hucksters will be thinned from the hurd!!! i see where he has his new machine out on the market now.
I'm a lil leary of the switch too, VERY short travel, when the pump out runs, it almost sounds like it's not working correctly (ya can here it in the video) 'cause it pumps out so often, on-off, on-off.. seems like that would either burn out the impeller or the motor way fast.That pump out looks like it might be problematic with that sensitive float switch and all.
It is High Flow, not sure of the GPM, but, it does come w/a big jetted wand, and is compatible to all the other RV attachments.This looks like a high flow system, are you supposed to change the jets on your tool to take advantage of the higher flow, would seem logical, the Demon uses big jets for a reason, if you don't have pressure you might as well have flow, something has to clean the emulsified soil....
No kidding! Then Jorge would have some real competition, seriously the video was very well done.probably should add a prespray segment to that video, as well as a prevac segment.
So ya wanna pimp it fer me?2" hose hookup, why bother with that 1.5" hose if it has a 200cfm vacuum sytem?
I was just thinking about that, I would add a small inline strainer to the sink connection, can't risk plugging jets.
Released in like October, they claim there's about 50 units sold.I wonder how many units are out there.
Englasio please? I ASSume those are jet sizes?trade out the K 1.5s for K3s.
Was thinking the same thing. :?As for high flow, using standard "double shut off" quick connects impacts high flow a bit, as does a standard 1/4" solution line.
Yes it does, according to the RV salesman.It's fine that it comes with an economy wand with BIG jets (oh wait...does it, or doesn't it?)
OVER HERE, HINT, HINT!JB said:Too bad RV doesn't know someone, who uses the SD REGULARLY, that would be willing to take CFX a while for real word experience, ya know, if they were to, Oh I don't know report it on a web forum, who knows he might even be able to sell a few. :roll:
HINT!
subtle? No?
JB said:Do you get a free bottle a looob w/that while the F*#& you up the a$$ ?
