- Joined
- Feb 4, 2016
- Messages
- 24,146
They’re getting better but not perfect yet. I soaked the tiles overnight in the acid. It ate through a bit of the deposits but not all. I’ll soak them in CLR next.What did those look like when new?
I’m diggin the socks homieThey’re getting better but not perfect yet. I soaked the tiles overnight in the acid. It ate through a lit of the deposits but not all. Ill soak them in CLR next.
What I’ve learned so far. Muriatic acid is some nasty stuff. Wear breathing and skin protection. Also I learned this stuff is great for releasing grout. It made all the grout turn into sand and just fall apart off the tile. So, if you guys have a job with porcelain tile with grout haze everywhere, clean it with muriatic acid. Wear protection and ventilation is a must.
Oh don’t encourage me.I’m diggin the socks homie
Isnt CLR just sulphamic (sp?) acid? How strong did you mix your MA? Maybe mix lil bit strongerThey’re getting better but not perfect yet. I soaked the tiles overnight in the acid. It ate through a bit of the deposits but not all. I’ll soak them in CLR next.
Oh no, I poured it straight in. It was strong. I don't know the make up of CLR. All I know is it's calcium specific.Isnt CLR just sulphamic (sp?) acid? How strong did you mix your MA? Maybe mix lil bit stronger
I don't think so..made all the grout turn into sand and just fall apart off the tile. So, if you guys have a job with porcelain tile with grout haze everywhere, clean it with muriatic acid.
thats how I first learned to do it, had a large area covered in hazeI don't think so..
No shitI don't think so..
