mosque
San Francisco, CA
I am proud of you.
Cause despite the fact that you are a "Very Small Animal" of a generally timid disposition, you try to be brave and on occasion conquer your fears.
Way to go Mardie.
so..........did anybody actually read the fooken question?
I did and thought about answering but got side tracked oops! olefin I charge less for small rugs $10-20 each you should get what you charge anybody else for these unless there's a lot. Wool goes up 50 cents a foot for the acid rinse on a clean item.
I want to price cleaning carpets in a mosque. The carpet consists of 3 foot wide runners laying side by side . They are about 20 feet long . The carpets looks like the standard runners that are seen on stairs and in older homes in the hallway . I did a burn test and it burned down with a black smoke. It must be some kind of blend. Has anyone had experience on this type of situation?
Whats your minimum??? mine is $75.00 for something that small I'd say it falls under minimum.
beagle
canada
bob
I was trying to get some information about the best way to clean these runners . They run across the room and seem to be attached together. I have never seen this before. I am wondering if they may buckle at the sides .
My guess is they will be fine but before you jump in blindly I'd ask. Have they been cleaned before? What method was used and what was the outcome.
We'd be a $1.00 foot and we will wear booties or what ever getup you want as long as you're paying. :icon_cool:
Reactions: SamIam and Brian H
Ann Arbor
Steve Lawrence
Pictures, wide angle and close up, would help get you pertinent replies.
N GA
BradFenstermaker
If you are worried, find out if they have been cleaned before.
Go your own test clean in a corner before doing the whole place.
If it was a min fee job I may would pass. If there is a chance for more work do it
