My Apex will only run in the override position..
D
dgardner
If he puts it back the way it was per your request - then my next suggestions wouldn't make sense.
it was just a simple switch back out a relay and hook a ground up to see what it did...
I didn't think that was to confusing......if it did not change anything..plug back in the new relay....
D
dgardner
Agreed, but me asking him to do the next step in troubleshooting the electrical while you had him put it back the old way would not have worked - he can't do both at the same time. I'm just politely waiting till you're done - no biggie.....
A
Able 1
OK, I put the new oil pressure switch in today and the electrical is back to normal, :rockon:but still runs rough..
There is a ground that goes from the negative batt. to a engine mounting bolt..
I'm going to mess with the fuel side after a big commercial job tomorrow.. I'm going to use it mostly for tile and my other van will do the carpet.
A
Able 1
I think I got it!! So when I put it under load the governor doesn't move, and if I physically move it the belts even out.. I grabbed it and it all loose and you can pull it about a 1/4 to 1/2" out of the hole..:headbang:
Reactions: dgardner
Good to here..hopefully it will end your problems with this machine........
Reactions: Able 1
J
JS41035
I just put about 120 hours on my apex. I really like the kubota. Fantastic single wand slide in so far. I bought used unit with 1600 hours for my busy season. I'll probably sell it this fall. Great heat. Sips fuel.
Reactions: SamIam and Able 1
Ya compared to a 405 the 570 use more gas to. think cause its running a little harder. more rpm's
