Oct 19, 2009 #1 F frank Member Joined Feb 26, 2007 Messages 78 Name frank pulido has anybody try it to do low moisture cleaning?
Oct 19, 2009 #2 Mikey P Administrator Joined Oct 6, 2006 Messages 116,974 Not enough weight to OP (grind in the dirt) but it makes a good little pre scrubber for real cleaning ala' HWE
Oct 21, 2009 #3 F frank Member Joined Feb 26, 2007 Messages 78 Name frank pulido why? I've seen some OP's about the same.
Oct 21, 2009 #4 Jeff Madsen Supportive Member Joined Dec 16, 2006 Messages 345 Name Jeff Madsen I owned one years back - it was a POS. The handle release mechanism will break on you, excessive vibration, screws holding the brushcup on to the main shaft shear off, excessive heat build up, etc. etc. My advice is to stay away..
